Results 1 to 2 of 2
- Sep 2008
- 54
February 19th, 2012 11:23 PM #1guys ask ko lang what are your experiences nun nagpa conversion kayo ng coilover sleeve tapos torno gamit yun old shock nyo then gas type... did you experiece having a huge gap on top coil spring going to upper strut mount. since having this kind of problem because of too much lower on the locking perches, nawawalan tuloy ng preload or tension yun spring which resulting to maalog or makalampag na suspension. anong solution ang ginawa nyo dito? others is using helper spring para maiwasan yun this kind of problem. kindly share your input guys.. thanks
- Sep 2008
- 54
high idle RPM at engine start
