Results 11 to 20 of 34
June 24th, 2008 11:52 AM #11
Does the defogger have any indicator on the dashboard panel? It might confuse the driver for that matter.
June 24th, 2008 11:55 AM #12
Thanks po...
Actually, ganyan talaga ang balak ko. Install a separate SWITCH, retain the old one, (kahit naka-paloob lang sa ilalim ng dashboard). Kaso, ang hiiiiiiiirap mag-acquire ng switch!
Pero doon ko pa rin ikakabit, kasi, balak ko ring mag-install ng central door lock switch dun sa location na sinasabi mo. Para hindi na kailangan mag-reach out ni misis para i-lock ang sasakyan kung bababa ako sandali.
June 24th, 2008 11:55 AM #13
Thanks po...
June 24th, 2008 12:14 PM #14
Not a big deal naman po in my case...
It will confuse the driver ONLY IF I don't tell him/her about the switch. Which most probably means s/he is a carnapper ... (Knock on wood)
I don't lend my rides naman basta-basta, eh. My Avanza is exclusively used by yours truly 99.9% of the time. My wife doesn't drive (yet). My best friend owns the hands that you see in the pics, and he's the next person who can drive this with my permission. Next in line will be my brothers, but they have brand new rides, too, so they don't have to borrow my Avanza. No one else is allowed to drive it.
June 24th, 2008 12:17 PM #15
June 24th, 2008 12:19 PM #16
Your right, ganon ang plano ko, deffoger or fog lamp switch, unfortunately 2500 ang cost ng switch na yan, sa casa lang nabibili, and wala din kasukat na surplus switch, for the mean time ordinary switch lang linagay ko...
Meron, pero iba pa AC switch yun yung puede mo patayin yung compressor lang while fan is on. Puede rin sa thermostat pero baka masira kakapihit
*woohoo; gumamit ka pa palang relay, di na kailangan yan kasi low current lang (mA) yan. Gumagamit lang relay pag high current 5 amps and above. Pero maganda pagkagawa nung sayo kasi nag soldering ka pa bat di ko naisip yun....
June 24th, 2008 12:32 PM #17
Na-measure ko kasi yung input voltage nung thermostat, +5V lang siya. So hindi pwedeng umilaw yung indicator light ng defogger switch (+12V). Saka mas convenient sa troubleshooting, tanggalin lang yung relay plug sa relay switch, ayos na.
June 24th, 2008 04:14 PM #18
June 25th, 2008 09:39 AM #19
June 25th, 2008 11:40 AM #20
