Results 1 to 7 of 7
- Jul 2008
- 15
October 10th, 2011 12:21 PM #1anu po kaya possible problem sa altis 02 manual nagiistart cya pero namamatay hindi na siya ma rev.na try ko na palitan fuel pump,crankshaft sensor,camshaft sensor.pero ganun pa din po nangyayari.may lumalabas check engine bago mamatay engine.may kuryente naman po sa mga coil.ok nman linya ng kuryente sa injector tsaka puel pump.pleas help.TIA..
October 10th, 2011 09:26 PM #2
If you're getting a check engine light, scan for codes.
Does it idle at all? If not, check your IACV. If it idles, but dies when you try to rev it, check your TPS.
But really, get it scanned for codes. Hard to diagnose the problem without more information.
- 52,731
October 11th, 2011 01:07 AM #3it seems you've already spent considerably on hit-and-miss remedies. i think it's time to have the experts with the proper equipment have a look. it might be cheaper than keeping on replacing this and that.
my 88 centavos' worth..
good luck.
btw, did you fill up from a gas station of unknown product quality?
- Jul 2008
- 15
October 11th, 2011 03:37 PM #4madali nman po siya mag start pero namamatay cya after 2 seconds.nagamit ko pa po ng gabi wala naman naging problem or lumabas na check engine before,tapos nung umaga na ganun na nangyari start pero namamatay.anyone altis owner na nakaencouter ng ganitong problem?anu po bang sensor ang nagbibigay signal sa fuel injector?para po kasi nagshushut off fuel injector. may maerecommend po ba kayo expert mechanic ng altis na.cainta po ang place ko.
- Jul 2008
- 15
October 11th, 2011 03:40 PM #5hindi na po cya nag idle kasi namamatay din agad engine.ang nangyayari po parang nagshushut off fuel injector.
- Jul 2008
- 15
October 13th, 2011 06:27 PM #6eto na po,pina scan ko po altis eto po lumabas p1310 code igniter circuit.possible po ba na computer box ito?un po kasi sabi nung nagdiagnose rerepair daw po niya ecu.anu pa po kya possible na sira may kuryente naman lahat ng coil.
- Jul 2011
- 584
October 14th, 2011 12:18 AM #7DTC P1300 Igniter Circuit Malfunction (No.1)
andyan procedures step by step: para lang may idea ka sa gagawin ng technician. HTH
Xiaomi E-Car
