Results 3,921 to 3,930 of 8993
- Apr 2014
- 28
May 1st, 2014 02:43 PM #3921sir noob question lang po pag "All in DP na po ba yun na po lahat babayaran then monthly na? or pag nirelease yung sasakyan may extra bayad pa? pasagot po thanks
May 1st, 2014 04:11 PM #3922
- Apr 2014
- 28
- Apr 2014
- 28
May 1st, 2014 11:28 PM #3924Mga sir ask na rin po yung mga nakakuha po ng Vios G M/T saan po pinakamababa ang dp and monthly na branch?
- Jan 2013
- 686
May 2nd, 2014 12:35 AM #3925
- Jul 2013
- 54
May 2nd, 2014 05:40 PM #3926Re: radio wont turn off with engine
Cause: loose fuse
Solution: take out radio fuse from fuse box (pls refer to ur manual for its location)-I used a long nose pliers for this. Inspect whether the fuse is ok (if not; replace). Place fuse back.
The radio would reset (preset stations & time will be back to default). But it would turn off with the engine.
Hope this helps
Posted via Tsikot Mobile App
- Jan 2014
- 655
May 2nd, 2014 06:14 PM #3927Umulan na naman kagabi at yung sa wiper ko ganun parin after few minutes maingay na nagshashake. Buti naglagay ako ng rainx medyo nakatulong.
Sinubukan ko gamitin yung wiper ng innova pinagpalit ko kaninang umaga, ganun din nangyayari. Yung wiper ko naman nilagay ko sa innova, ganun parin pero masminimal. Ano kaya problema? Try ko dumaan sa toyota pag balik ko ng manila next week wag lang sana umulan pa ulit.
May 3rd, 2014 02:30 AM #3928
Applying Rain-X will cause your wiper to skip and shudder. It's very hard to remove the chemical from windshield. Used watermark remover and a lot of elbow grease plus soap and water, took weeks to remove Rain-X.
- Jun 2005
- 3,769
May 3rd, 2014 09:20 AM #3929pardon my ignorance but im not seeing a real solution here. i think the real questions are where is the radio getting its current from? and, why is it intermittent.
replacing and reinstalling the fuse just resets the radio and does not remove faulty wiring (in case)
Sent from my Thrill 430x using Tapatalk 2
- Jul 2013
- 54
May 3rd, 2014 09:44 AM #3930I believe its a loose fuse, not an intermittent electrical flow. Pls. Note that it mighy not also be a busted fuse as I did not replace it (nor was the circuit breaker broken).
Hence: I believe the real cause is loose fuse and the soln is to reafix it. If you have another proven soln, pls share
Btw, this solved my problem, hope it also solves yours. Just trying to help.
Wala parin spare tyre?
2025 Nissan Kicks
