Page 116 of 286 FirstFirst ... 1666106112113114115116117118119120126166216 ... LastLast
Results 2,301 to 2,320 of 8996
    Jan 2014
    Guys help naman..
    May nakaayos n b ng rattling sa dashboard?..sa akon kc 3 beses ko na dinala sa casa,bumabalik after ng ilang araw.
    salamat sa mga sasagot,na oc n ako dito.
    Quote Originally Posted by cubes3780 View Post
    Guys help naman..
    well, yung sakotse ko (innova), kumakalog ang laman ng glovebox. at yung glovebox cover mismo, kumakalog..
    Oct 2009
    Guys help naman..
    Siningitan ko ng foam. Yung pang dishwashing. Ayun nawala. 5 times ko dati dinala sa casa yan. Twice na inayos ng taga TMP hindi nila maayos. Kasi by the book sila kaya hindi hindi maayos ayos..
    Feb 2014
    update lang po ok na stereo ko,, sabi nila may problema sa fuse daw
    Jul 2013
    Quote Originally Posted by musica View Post
    Sir ano po ginawa? I'm having problems with my stereo not automatically turning off when I turn off the engine
    Posted via Tsikot Mobile App
    Feb 2014
    Quote Originally Posted by Huyu View Post
    bale po 2nd time na nagkaproblema stereo ko yung 1st ayaw gumana so check ko ng fuse ayun umangat pala bale inayus ko lang then umandar ulit, 2nd , last 2days lang pag hila ko ng key umaandar pa rin hindi na cia auto on and off. kaya napilitan na akong idala sa toyota sf kanina. so ayun tiningnan yung unit wala naman daw problema. in the end sa fuse daw talaga pinalitan lang then ok na cia now
    Feb 2014
    Have you seen those pure yellow 2013 vios. The airport metered. Grabe. Soobrang suave and sophisticated ng looks nya.Tinanong ng gf ko kung ganun daw ba ichura nung vios ko. Bat daw mas maganda daw yun kesa sa koche ko. Black lang akin. Pero seriously kahit ako napanganga dun sa pure yellow na 2013 vios.
    Apr 2014
    Mga sir, tanong ko lang ulit.. Does our vios comes with immobilizer feature? Mine is 1.3E M/T. Paano ba malalaman if it is equipped with this security feature? Thanks
    Jan 2013
    Quote Originally Posted by rondels01 View Post
    Mga sir ask na rin po yung mga nakakuha po ng Vios G M/T saan po pinakamababa ang dp and monthly na branch?
    Sir inquire ka sa Toyota North Edsa.. i got an excellent deal from them and they also have excellent after sales service.. pm me if interested.. i can refer you my SA..
    good luck..
    Jul 2013
    Re: radio wont turn off with engine
    Cause: loose fuse
    Solution: take out radio fuse from fuse box (pls refer to ur manual for its location)-I used a long nose pliers for this. Inspect whether the fuse is ok (if not; replace). Place fuse back.
    The radio would reset (preset stations & time will be back to default). But it would turn off with the engine.
    Hope this helps
    Jun 2005
    Cause: loose fuse
    Hope this helps
    pardon my ignorance but im not seeing a real solution here. i think the real questions are where is the radio getting its current from? and, why is it intermittent.
    replacing and reinstalling the fuse just resets the radio and does not remove faulty wiring (in case)
    Sent from my Thrill 430x using Tapatalk 2
    Jul 2013
    Quote Originally Posted by sirkosero View Post
    I believe its a loose fuse, not an intermittent electrical flow. Pls. Note that it mighy not also be a busted fuse as I did not replace it (nor was the circuit breaker broken).
    Hence: I believe the real cause is loose fuse and the soln is to reafix it. If you have another proven soln, pls share
    Btw, this solved my problem, hope it also solves yours. Just trying to help.
    Nov 2013
    Gaano ba katagal bago ma-release ang OR/CR?
    3 months na wala pa rin daw sabi ng agent.
    Feb 2014
    Quote Originally Posted by SneezyPepper View Post
    same issue here, binangga yung vios ko last month, dun ko lng na realize na wala pa pla akong ORCR nung hinihingi na nung pulis...
    Jun 2005
    methinks a loose fuse should cause the radio to turn off and not on because losing fuse contact should cut the circuit.
    i also noticed that my radio turns off a second after i switch the engine off. not bothering me much though.
    what bothers me most is that i only get 10km/li on a highway drive at 60-80kph. my gen2 got 15km/li while on convoy.
    Jun 2005
    Cause: loose fuse
    Hope this helps
    btw, did u notice yung speaker go on and off? minsan kasi yung right speaker lang may sound eh...
    Jul 2013
    Yes I had the same experience. I upgraded my speakers though and I didnt have the same problem since.
    Jun 2005
    but you kept the stock radio? did u install new rear speakers as well?
    Jul 2013
    Yup stock radio, ryan audio seps, amp and subs. No need for rear speakers
    Jan 2014
    Umulan na naman kagabi at yung sa wiper ko ganun parin after few minutes maingay na nagshashake. Buti naglagay ako ng rainx medyo nakatulong.
    Sinubukan ko gamitin yung wiper ng innova pinagpalit ko kaninang umaga, ganun din nangyayari. Yung wiper ko naman nilagay ko sa innova, ganun parin pero masminimal. Ano kaya problema? Try ko dumaan sa toyota pag balik ko ng manila next week wag lang sana umulan pa ulit.
All New 2013 Toyota Vios (3rd Gen)
