Results 4,721 to 4,730 of 8993
- Jun 2005
- 3,774
July 6th, 2014 01:35 PM #4721
July 6th, 2014 02:27 PM #4722
I got 3 SA's from toyota (Makati, Otis, North Edsa). But i will recommend this sales. Sobrang mabilis at efficient mag asikaso at sobrang helpful even aftersales. When I bought my third car which is the 3rd Gen sa kanya ako kumuha contact her 09062137651 Len Centeno.
Posted via Tsikot Mobile App
- Sep 2013
- 505
July 6th, 2014 05:10 PM #4723finally able to rewire the DRL LEDs that were tapped to the park lights. i had it rewired, supply niya yung galing sa power windows and relay trigger yung park lights. LED goes on when the key is in ignition, turns off when parklights are switched on. also able to install a bulb in the rear left foglamp. buti may nakakalat na old bulb housing for a taillight. tapped nga lang sa tail light. walang rear foglamp switch eh.
now, may nabibili bang clear lens for the right rear foglamp assembly?
- Sep 2013
- 505
July 6th, 2014 11:00 PM #4724how much kaya sa casa yung 30amp fuse ng power window? napaputok ko kanina eh. also any alternative shops?
- Jan 2014
- 655
July 6th, 2014 11:23 PM #4725
- Apr 2014
- 55
July 6th, 2014 11:47 PM #4726As I thought hindi kakayanin ipagsabay ng fuse ng power window at ng DRL. I might not help you with the price but let me just give you an advice.
If you are adding electronic components, always get source voltage from the battery.
Sample circuit po ng "medyo safe" para sa DRL.
May nakakaalam po ba sa inyo ng magaling na auto electrician malapit sa Mabalacat City, Pampanga? Balak ko po kasi magpainstall ng rear fog lights. Kaya lang first auto ko ito kaya ayoko pagexperementuhan. May circuit design na din po ako sa RFL.
- May 2014
- 5
July 7th, 2014 02:22 AM #4727Normal ba ung cranking sound pag nirerelease ung breaks pag nagrereverse? 2 weeks palang vios ko less than 2k odo.
- Jun 2014
- 20
July 7th, 2014 08:09 AM #4728Mrkampante- apakan mo maige ang clutch bago mo i cambio. Di ka naka diin ng husto kaya ganun.
- Jun 2006
- 1,139
July 7th, 2014 08:33 AM #4729DRL led should be low power, less than 1 amp. Kung napaputok nyan ang 30amp fuse mo, somethings wrong with your wiring. The largest LED i have is my 15w headlight and that onle eats around 2 amp, with fan pa yon.
- Feb 2014
- 97
July 7th, 2014 08:44 AM #4730
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
