Mga Sir,
Hingi lang ako ng info kung ano gamit nyo na Spark Plug for Corolla 2E engine at kung ano yung my best performance and efficient fuel consumption.
Ang sabi kasi sa Corolla Diagram is
W16EXR-U11 spark plugs
Any comments?![]()
Mga Sir,
Any comments?![]()
Just use Toyota Denso OEM spark plugs. Php55 each, if you like change it every 5,000kms PMS.
Kung stock mode ka, no big gains using high end spark plugs and high tension wires.
Just use the correct tire PSI, Engine timing at 10degrees and step on the gas gently. My previous car , a 1993 XE did 10kms per liter in city driving
I used NGK sparkplug at Premium gasoline na kadalasan kahit sinong makausap mo pag nilagyan mo ng unleaded reklamo nila may tope ang makina.
Sa akin, NGK BPR6EY. Yung original spark plug (walang butas sa tip na kinakabitan ng high tension wires)..inaabot ito ng several years! Basta't linisin lang ang firing tip from time to time.
