Results 1 to 2 of 2
- Sep 2008
- 54
October 11th, 2010 01:25 AM #1guys. i need help of the expert regarding my a/c compressor. napansin ko kasi lately humihinto un magnetic clutch ng compressor ko. pero in the long drive ok nman sya, di ko napansin na nagloko.. pero pag once na nakapark lang ako at naka on ang aircon nag sstuck up ang magnetic clutch. ano kayang problema nito? bagong overhaul lng ng compressor/ linis at palit freon. pls help me. thx.
- Nov 2009
- 456
October 11th, 2010 03:22 PM #2It may be a malfunctioning relay, magnetic clutch...or low refrigerant...or a dirty condenser. It could also be a failing thermoswitch for the aux fans. Better bring it back to where you had the aircon cleaned. If they can't fix it, find a more competent shop.
high idle RPM at engine start
