Results 1 to 4 of 4
    Mar 2011
    Hello Sirs,
    I have a problem with my car last saturday nag overheat ako suddenly pag park ko may nag leak na water sa ilalim dun sa area nang parang timba ba ung hitsura niya then ung wire nang radiator fan ko sunog.
    ano kaya pwedeng gawin dito sa problem ko
    Regards;
    Roland
    Feb 2009
    Quote Originally Posted by lands_drock View Post
    Hello Sirs,
    Regards;
    Roland
    1. do not use plain water for coolant- it does not have the corrosion protection, does not have boil protection, does not have freeze protection and does not lubricate cooling system components
    2. repair the damaged radiator fan wire- this might have been the cause of the overheating in the first place
    3. was it the car overheating or yourself
    Mar 2011
    Hi Jick,
    Yes I tried ti repair the fan but still nasunog ulit heheheh ung car ang overheat sa akin hehhee
    Jun 2011
    Sir,better to replace your radiator cooling fan assembly.including the plastic shroud.Ang naging cause ng pag overheat mo is ung pag hinto ng cooling fan(wear & tear).kaya naman nasunog ung wire kse nag short na ung fan motor.ang tendency kse ng fan pag hindi na umikot at may power supply is masunog ung motor.Madami naman nabibili nyan na surplus P1,500 salpak kagad.
AE101 - Over Heat
