Results 1 to 10 of 59
May 25th, 2011 03:35 PM #1
Worth of 1k ang naikarga,
Don't know if it's a driver(lady) fault.
Biglang umitim ang lumabas sa exhaust then di na umandar.
Pinadrain na ang lahat nasa fuel(naka-tilt up ang front side).
Tanong: Ano ang possible na masira?
May 25th, 2011 03:48 PM #2
May 25th, 2011 04:08 PM #4
Still, I find the entire situation funny.. ano kaya reaction ni xda yun nalaman niya.. must be: "<insert expletive>, bat mo nilagyan ng diesel eh gasoline yan?!"
Bro CVT, paano mo nasabi that a diesel-engine fed gasoline is worse? Piqued my interest tuloy
May 25th, 2011 04:13 PM #5
May 25th, 2011 04:18 PM #6
Diesel in a gasoline engine: Since diesel won't ignite when the spark plugs go off... it won't explode. It'll die on you. Clean off the plugs, drain the fuel system, and you're all right.
Gasoline in a diesel will, over time, destroy the fuel pump as it dries out the lubrication. If you run it long enough, the lack of lubricity will also the inside of your engine. If you fill a nearly empty tank of diesel with gasoline... then that's even worse...
I shudder to think about what it'd do to the sensitive components of a direct injection (CRDI) diesel... but the same can be said, I guess, for diesel in a direct-injection gasoline motor...Last edited by niky; May 25th, 2011 at 04:36 PM.
May 25th, 2011 04:25 PM #8
kaya ako....pag nagfi-fill up, naka tingin ako sa attendant kung ano ilalagay nyang fuel sa tsikot ko.
May 25th, 2011 04:33 PM #9
May 25th, 2011 05:01 PM #10
Happened to our Corolla before. We just drained the tank, carb and cleaned the plugs and all was well.
Dapat nilalagyan ng sticker na "Gasoline" (na may picture ni Calvin na nag-weewee). :D
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
