Results 1 to 10 of 33
- Mar 2006
- 14
April 18th, 2007 04:08 PM #1I have 95 corolla GLi.
Engine:4AFE
Transmission: C50 ata?....
I would like to know if tama lang ba ang 3000RPM at 100KPH?
Ang alam ko dapat 2500RPM lang sa 100KPH.
I just replaced: Clutch disc and pressure plate
Clean throtle valve....still the same.
Any suggestion?...
April 18th, 2007 05:39 PM #2
- Mar 2006
- 14
April 19th, 2007 07:46 AM #3My tires are still new. Aboout 90%. size: 185/65/14. same as stock.
Factor kaya ang spark plug? Medyo worn na rin pero sabi nung mekaniko, ok pa daw yun.
- Mar 2006
- 14
- Mar 2006
- 14
April 21st, 2007 07:44 AM #6Siguro nga hindi na accurate yung speedo ko.
Feeling ko kasi parang hindi 100kph ang takbo ng auto ko.
tnx po.
April 21st, 2007 05:42 PM #7
This is at 5th gear? Halos lahat ng kilala ko na mostly stock-stage 1 mods e ang 5th gear 100kph is just under 3k rpm. Your car is normal IMO.
Shameless promotion, pero try asking sa clubae at www.clubae.proboards104.com. It's an all car car club, pero most members have Toyotas, specifically Corollas (hence AE, although it also now stands for automobile enthusiast).
Daming naka bigbody dyan, like myself. hth
- Mar 2006
- 14
April 25th, 2007 07:18 AM #8Yes its at 5th gear. Thank you po sa info. I visit the site you posted.
- Feb 2007
- 13
- May 2007
- 8
May 22nd, 2007 02:36 AM #10Good day Sir...Tama po yun 3000rpm* 100kph, 3200rpm* 120kph; 3500rpm* 140kph; 4000rpm* 160kph. Yan po kompleto detalye kasi base yan sa top speed gear ratio plus yung final gear ratio.
Every day pagpasok sa office ko 120kph madalas ang speed ko..pag wala pa police 140 to 160kph.
Kung spark plug ang problema ramdam mo siya sa arangkada. Try to use iridium spark plug mahal lang siya pero matagal naman kumpara sa platinum. Kailangan din yung langis mo wag paitimin ng husto (cause pumping & frictional loses) mas maigi na yung mineral base kasi panay ang change oil kesa naman sa synthetic naiipon ang dumi sa langis (nagiging burak o kaya bumabalot sa mga journal). Use Oil viscosity 10w-30. Be sure brakes always ok...
The ₱613,000 discount is until June 31, 2024. Note that the Peugeot 5008 used to retail over 3M...
2018 Peugeot 5008
