Results 31 to 33 of 33
- Jul 2010
- 166
September 19th, 2010 04:19 PM #31sa tingin ko po yung rpm gauge ko may problem, paano po nirerepair ang rpm gauge? electronoic po yata yun di ba?
- Jan 2007
- 2,234
September 19th, 2010 04:56 PM #32The only possible culprit here is your clutch, or a faulty gauge.
It's impossible for mods like spark plugs, air filter, ignition coils or basically anything inside your engine bay to affect your driving RPM, because your engine speed is tied to your transmission. Doesn't matter how strong or how weak your engine is, when you're driving there is a straight mechanical link between your engine, transmission and the road that basically locks your vehicle speed and engine RPM (per gear) together.
So if your driving RPM is being changeable, then something is slipping -- likely the clutch. Otherwise you'll get the same 3000rpm at 100kph (based on the original post) every single time.
If you really want to cruise at a lower RPM, what you need to change are the transmission gear ratios, or the final drive.Last edited by Dr.Kamiya; September 19th, 2010 at 05:06 PM.
- Jan 2007
- 2,234
September 19th, 2010 05:03 PM #33
Xiaomi E-Car
