Results 1 to 10 of 11
November 16th, 2022 06:25 PM #2
5th Generation
All-new 2023 Toyota Prius debuts with sportier look, more power | Autoindustriya
Underpinned by the new second-generation TNGA platform, the all-new Prius gets a lower center of gravity and provision for larger-diameter tires.the all-new Prius is being offered with the brand's two types of hybrid systems which boast a significant improvement in both performance and efficiency. The plug-in hybrid consists of the 2.0-liter Dynamic Force engine that puts out 223 PS, with an EV driving range about 50% higher than the previous model thanks to the new lithium-ion batteries.
The other hybrid system is a series-parallel type, with either a 1.8-liter or 2.0-liter engine paired to the electric motor. The maximum system output of the 2.0-liter version produces 193 PS – 1.6 times more powerful than the outgoing model. The series-parallel system also comes with the E-Four system, making the all-new Prius tackle low-friction surfaces with confidence.
- Jul 2009
- 2,618
March 21st, 2023 11:20 AM #5
BIMS 2023: Next-gen Toyota Prius makes ASEAN debut | Autoindustriya
The 2023 Prius is available with a 1.8- or 2.0-liter engine that’s accompanied by an electric motor and a lithium-ion battery pack. Toyota says it can produce up to 193 PS which is 1.6 times more powerful than the outgoing model.
Like most of its Toyota brethren, the all-new Prius now comes with Toyota Safety Sense.
September 13th, 2024 10:26 AM #7
Toyota PH to launch all new 2025 Prius HEV? | Autoindustriya
We got hold of information that Toyota Motor Philippines has received approval for a vehicle that has a 1798cc engine displacement. When you run the numbers, that exact engine displacement points out to the 2ZR-FXE – the same 1.8-liter Atkinson cycle engine that powers the Corolla Altis and the Corolla Cross. But since the Corolla Altis and Corolla Cross have already received a model update recently, the approval makes more sense for a new model.
- Nov 2019
- 1,427
September 13th, 2024 11:02 AM #8
September 13th, 2024 11:17 AM #9
Tsikot Member Rank 3
- Nov 2002
- 1,990
September 13th, 2024 01:48 PM #10I wonder if it would be the Prime model which is a PHEV.
It would have very few customers if priced over 2M but worth it if its the Prime(PHEV) model.
^ napanood konnga iyan kanina Kasi biglang bumulaga sa timeline ko. Unfortunately, I made it only...
Mineral , semi synthetic or fully synthetic?
