Results 171 to 180 of 324
March 14th, 2019 08:40 PM #171
- Feb 2019
- 32
March 14th, 2019 08:47 PM #172I did. Walang lock. What happened is I wanted to check the engine braking sa downhill so I switched from D -> M1 then pagdating ko sa baba, I switched up all the way to reverse instead of right. When I stepped on the gas, na-off ang engine.
- Jun 2005
- 3,774
March 14th, 2019 09:07 PM #173Yout gate shifters look like this. So from M+, to reverse, you need to do the following:
Go to D
Move the shifter up to neutral,
Move the shifter left then move to shifter up to reverse.
All these while stepping on the brake. Mahirap na accident ito imho....
Sent from my MI MAX 2 using Tapatalk
- Feb 2019
- 32
March 14th, 2019 09:20 PM #174After I reached the flat, the car was at crawl speed. Then I mindlessly set the tranny to R. No brakes were pressed. But in theory, if this happened only once, may damage ba sa tranny?
Sometimes, speed humps auto changes my tranny from D to N. Happened twice already.
- Sep 2018
- 8
March 14th, 2019 11:18 PM #175Im about to get XE, based on the upgrades that was mentioned on prev pages, Im thinkin of putting body kits. Any suggestion as to where? thanks
- Sep 2018
- 8
March 15th, 2019 01:01 AM #177
- 52,731
March 15th, 2019 01:04 AM #178
- Feb 2019
- 32
March 15th, 2019 06:17 AM #179Yes. Pag dating ko sa hump, I slowed down just enough para maka climb si front wheel. Once cleared, I lightly tap the gas para may enough speed si rear wheel to climb as well. It’s as this point na biglang tumaas ang sound ng makina. Naka N na pala. I’ll save the video next time when it happens again. Thanks.
- Feb 2019
- 32
March 15th, 2019 06:22 AM #180
Xiaomi E-Car
