Page 1 of 16 1234511 ... LastLast
Results 1 to 10 of 560
    Aug 2006
    Here's another problem with Innova gas tank and I knew Toyota Phils. knows this problem and still keeping their silence.
    Here in Tsikot, there are already a lot of owners who do experience this problem not just once but twice or three times during the warranty period. But some like me have shoulder the cost of replacing it because I'm not aware that this is due to faulty design and components.
    Here's my first gas tank, replaced using my Insurance claim and paid for my participation. Toyota only replaced my gas tank assembly.
    Then after less than 9 months, the gas tank again warped on the same spot. This time I already knew that this is a real defect from components and negative pressure build up is flipping my gas tank floor inward, I tried opening the gas filler cap and instantaneously a loud flipping sound of metal from the gas tank could be heard. This explains the cracks and fuel leak, the constant flipping out and flipping in of gas tank floor weakens the cornered portion of the gas tank just beneath the front strap.
    Here's the picture of my second gas tank, claimed under warranty that took me around 2 months to battle my claims with TMP. See how deep the the dent on the gas tank floor due to negative pressure. Together with replacing my gas tank, TMP also replaced my Charcoal Canister assembly and Filler Cap. I'm still hoping it won't happen again
    Picture of warped gas tank showing how large is the dent due to negative pressure.
    Other owners who experienced this, just show up and be counted, and to other owners who will experience this and your unit is still under warranty, be firm to claim it under warranty as this is really due to faulty components.
    To the moderators, please have this thread sticky to warn others and to let them know that they should claim it under warranty.
    Is this limited to petrol or diesel only?
    Aug 2024
    Quote Originally Posted by mikelsy View Post
    "That’s frustrating! If it’s a known issue, Toyota should address it transparently. Consider joining other affected owners to push for accountability or reimbursement, especially if it stems from a design flaw."
    Jan 2010
    May i know what is the effect of his problem? Does it only waste your fuel?
    I encountered a problem also but I'm not sure if it's related to this. My fuel gauge displays a warning light so i went to a gas station. I told the gas boy "full tank until 1st click" and so he did. Surprisingly, the nozzle clicked eventhough my fuel gauge only displays 3/4 filled. So I left there anyway and drove home. After several km i drove, i went back to the same station to have it refilled until 1st click. But still it stopped until 3/4 display of the gauge. He said that this kickback is normal if the nozzle detects pressure in the gas tank. Is this true? Have you experienced this? so i told him to continue refilling it and there, it clicked and gauge says full.
    Any inputs will be appreciated!
    Sep 2008
    fyi
    lahat ng fuel tank meron breather for purpose of vacuum. Otherwise parang zesto yan. maging chicharon ang tank.
    Mar 2007
    So does this mean sa breather ang problem?
    Yes, I was wondering about the same thing.
    The fuel tank should not have a vacuum pressure inside. This could mean the fuel tank breather tube or breather check valve is either faulty or installed improperly (wrong direction).
    Constant expansion/retraction will lead to metal fatigue.
    This should really be addressed by TMP.
    Thread is a sticky now.
    Speak up and be counted.
    Jun 2010
    *miles2
    Same problem here. Mine was replaced recently. Do you know where we can sell this defective fuel tank?
    Aug 2006
    Quote Originally Posted by tggerhapi View Post
    *miles2
    Actually the gas tank can be repaired using hot rod and lead. I have seen at the dealers service bay that they also repair gas tank via outside contractor, the contractor pulls out the defective tank and then returned after the repair. I ask the contractor and he told me he is from Paranaque and they would do a water immersion technique and hot rod with lead, "suplete" at "tingga".
    Have you also replaced the "Charcoal Canister" and the "Filler Cap"? If not there is a huge possibility that your new gas tank will get warped and leak again just like what happened to me during my 1st gas tank replacement.
Toyota Innova Gas Tank woes
