Page 11 of 23 FirstFirst ... 78910111213141521 ... LastLast
Results 201 to 220 of 780
    just got my unit. so far no jerk felt. Just wanted to ask hindi ko kasi makita, where is the Transmission fluid stick located?
    Mar 2004
    Same people who complain why there is no diesel engine for this and that vehicle. Then when they introduce a diesel model everyone complains about the price. e.g., Mazda CX-5 and Mazda 6.
    May 2016
    Quote Originally Posted by edricdude View Post
    There is no dipstick to check atf. I would recommend that you have it checked at your casa.
    Sep 2012
    Nag try ako sa NLEX mag sports mode, during 100kph nasa 6th gear (drive mode) tapos bigla ko nilagay sa sports mode nagdownshift sa 4th gear. Tama ba yun? Eh yung dalawa ko auto kapag nilagay sa sports mode di siya magdownshift at imaintain lang yung current gear.
    Mar 2004
    Different company, different model, different automatic transmission programming.
    Quote Originally Posted by sparcom2 View Post
    If your speed is 100 kph ... and set to SportsMode.. it should be at least 5 or 6th gear.
    Sep 2012
    Quote Originally Posted by wrcastro_ph View Post
    Exactly, di kaya Transmission Control Module ang may diperensya?
    Jan 2013
    As per manual, default of S-mode is 4th gear. Di ko pa nabasa kung may settings ito.
    Sep 2012
    Quote Originally Posted by rhounael View Post
    Badtrip yan, sana may settings. Buti na lang 100kph lang takbo ko, pero matindi engine break na that speed.
    Jan 2013
    oo nga sir at hindi ko alam kung anong logic behind kung bkit ganun ang settings na ginawa ng Toyota
    ngyn lng ako nk-encounter ng ganyan... usually tlga kung anong naka-engage na gear from Drive e dpat yun
    Sport mode is only a throttle response adjustment. When you were driving at 100kph, your accelerator was probaby depressed an inch or two. But at the same accelerator position using sport mode, the throttle is much stronger hence 4th gear. It basically shortened the throttle response. Not the best explanation. I still need my coffee.
    Jan 2016
    Has anyone who has this issue checked their ATF level if its not less than the minimum required?
    Sent from my SM-G530H using Tapatalk
    May 2016
    Quote Originally Posted by watarii View Post
    sir what if there is oil leak already? related pa ba sya sa transmission? or ibang parts na naapektuhan? meron nakita ksi sa floor galing sa ilalim ng makina. dont know if its because sira tlaga tranny or meron ng ibang naapektuhan
    Jan 2016
    Quote Originally Posted by mauy22 View Post
    The idea kasi is baka kaya nagje jerk kulang sa ATF. Para ma rule out sana
    May 2016
    so possible po sir na dun nanggagaling leak? tama ba? im just worried ksi brand new to, very unusual na magka leak. so baka ksi meron na ibang problem.
    May 2016
    According to my service advisor they already checked my transmission fluid. Still the same.
    Mar 2004
    Maybe it's the aircon water that you saw under the car.
    May 2016
    black sir eh...
    Jan 2016
    black sir eh...
    Im saying in general boss may leak or wala basta kung kulang ba ang ATF
    black sir eh...
    Take pictures and escalate to your SA asap. They need to fix it asap. Share your experience sir. Thanks.
    These leaks are worthy of media attention ��
2016 Toyota Fortuner Jerky Transmission
