Page 73 of 156 FirstFirst ... 236369707172737475767783123 ... LastLast
Results 1,441 to 1,460 of 5286
    Replace headunit with a faster one ...
    For the reverse camera ... try Benjie of MASPRO in Banawe ... or Louie of Lamson Digital in Jose Abad Santos ...
    - thanks sir. God Bless...
    Sep 2010
    Quote Originally Posted by sparcom2 View Post
    Saan ka bumili RCA cable?
    Sa banawe lang sir. P300 yata if I remember correctly.
    May 2011
    Hi guys. Anyone here who knows how to disable the beltminder on the passenger side?
    Sent from my SM-G925F using Tsikot Forums mobile app
    Quote Originally Posted by vin23 View Post
    there are dummy bayonets that you can purchase from the mall car accessories stores, po.
    Oct 2015
    hello mga sir, refer ko lang po 2016 fortuner v ng pinsan ko, after ng carwash daw kasi nya di na nagwork yung power door lock sa trunk kahit i press yung button sa trunk or sa keyfab, naamin ng wash boy daw na na pwersa nya closed yung boot without pressing the button sa trunk. May quick fix po ba? After xmas pa raw kasi sila makaka luwas if ever sa casa papaayos. Thank you very much po mga sir.
    Mar 2004
    Closing the rear door without pressing the button won't damage the mechanism ...
    Oct 2015
    That's good po kung ganun. Pero how come po not working na yung both buttons ng door at key after the incident. Possible po kaya na triggered ang auto door lock settings to off kung ganun kaya di working yung buttons? Thanks!
    Feb 2011
    Quote Originally Posted by Lego317 View Post
    Baka naman po napindot lang yung button para i-on/off ang power door. Nsa bandang ilalim un ng manibela yung switch.
    Aug 2013
    hi guys. I recently applied glass watermark remover all around the car...perfectly fine except on the right side mirror. It gets foggy it didn't worked well. Covered pa po ba to ng warranty???
    Toyota's manumatic mode is really different.
    It isn't like other brands that will really shift to the desired gear (as long as the revs can handle it - not too low or not above redline).
    It's more of D6, D5, D4...D1. If you put it in 6, it'll use gears 1 to 6. If you put it to 4, then it'll use 1st to 4th gear. The "manual mode" only sets the highest gear the transmission will use.
    correct
    Hehe. Reminds me of our old 95 accord at. Pareho lang operation but of course only 4sp and pig slow to change gear. Smooth though.
    Nov 2007
    Usually you cannot apply watermark remover sa side mirrors.
    Most brands i saw before say it on the bottle. Kindly check on yours.
    Aug 2013
    Quote Originally Posted by JJB View Post
    I did check before applying. It cannot apply in some side mirrors that's why it suggested to test it first in small portion. Which I did, in fact it worked on the driver side but when I applied on the opposite, that's where the dilemma started!
    Actually, I don't suppose need to apply on side mirrors nadamay lang talaga since I applied all over why not lahat na. I was so over excited...my mistake hehe
    But at least lesson learned http:////cdn.tsikot.com/forums/image...es/biggrin.gif
    Aug 2013
    But at least lesson learned...:D
    Oct 2007
    Do you guys still turn off the AC before you turn off the engine or no need to turn off the AC na?
    Sent from my S7 Egde
    Mar 2004
    Turn off the aircon ... less load and stress when starting the engine ...
    Jul 2016
    On these all new suvs/cars on the road, ecu is now intelligent enough to disenage a/c compressor when starting/cranking engine.
    The real benefit of turning off AC and putting blower to max is that is removes moisture and increases evap temp to ambient. Less prone pamahayan ng molds/bacteria na nagcacause ng mabahong amoy ng ac especially in our hot and humid climate.
    Oct 2007
    Quote Originally Posted by Janemar View Post
    Thanks mga sir for the input, upon reading the owners manual, they didn't mention on how to turn the AC on, I tried pressing the AC button but it didn't turn on, it will just turn on if you press the auto control, unlike on my Mazda 3, you can turn on the ac when you press the AC button but sa fortuner ayaw.
    I forgot to mention mine is a 2WD 2.4V pearl white, bought last December 22.
    Sent from my Nexus 7 using Tsikot Forums mobile app
    Brought the Fort to Nasugbu Batangas. Passed through Pico de Loro rolling zigzag on the way back to Manila. There is a problem with the clutch, especially on fast downhills. The gears seems to be stuck and remain in high rev at about 2k rpm even without stepping on the gas...have to continually press the brakes to slow down enough for the gears and the revs to go down. Between 80 kph and 40 kph. My transmission was changed before and the recieved the update program for the downshift jerk. Anyone experienced a similar anomaly.
2016 Toyota Fortuner
