Page 154 of 156 FirstFirst ... 54104144150151152153154155156 LastLast
Results 3,061 to 3,080 of 5286
    Oct 2007
    I always check my oil in the morning.
    Oct 2019
    kumsta mga check mo boss nag babawas ba?
    Oct 2007
    Quote Originally Posted by jhunjun View Post
    Parang wala naman sir
    Oct 2019
    Planning to use ung ZIC x7 10w 40 -- diesel for fortuner... ok kaya un?
    Sep 2012
    I need to chang my ATF, sino dito nakapag change na ng ATF using dialysis method? saan at magkano inabot?
    Quote Originally Posted by sparcom2 View Post
    I did dialysis for our then 2009 sta.fe. though I cannot categorically state na yun dialysis ang cause after nun nabali yun input shaft nun A/T. buti na lang under warranty to the tune of 500k for replacement. we had to wait 6mos for the parts. theory ng mga nakausap ko is yun dialysis ang nag loosen ng gunk debris kaya nasira. if I remember correctly 16 liters ata nagamit total flush and refill fluid na. di ko na maalala presyo. servitek ginawa.
    I would say best is to go with a simple drain and fill. if it is your schedule then change the filter/strainer as well.
    otherwise only go for dialysis as a last option. for example you are already having tranny issues. delayed shifts, crunching or rough shifts. hth
    Sep 2012
    Dialysis method ang ginagawa ko sa gen1 fortuner, innova and super grandia. No problem so far, kaso sabi ng mechanic ko wala pa siya ginawa gen2 fortuner. Ayaw niya magtake risk baka daw magkamali siya. I always replace my ATF every 40k km.
    Plan ko kasi iupgrade ng fully synthetic ATF kaya kailangan dialysis method para mapalitan din yung nasa torque converter
    Mar 2005
    WS na daw gamit nung Gen 2 Fort na ATF nung nag inquire ako sa casa. Sa manual parang wala ko nakita kung kelan palit ATF ng Fort.
    Mar 2005
    Ouch, naka 2 ATF flush ako sa 09 Santa Fe ko sir buti di ko na encounter yan hanggang sa nabenta yung unit ko.
    Quote Originally Posted by jmpet626 View Post
    Good for you Sir. as I said I cannot din naman 100% attribute it to dialysis as the cause without evidence. In hindsight also baka naka apekto din yun flushing fluid na ATF (Total). yun final fill lang namn yung spec ATF ng hyundai talaga. In fairness also the sta.fe is still doing fine noe with my cousin who bought it. mag 100t kms. na.
    Mar 2005
    Possible sir, meron sa SF forums nalagyan ng Shell ATF na hindi naman SP3 rated yung shell atf pero na drain din naman upon advise ng mga taga forums.
    Lemon yan. Hindi nababali ang input shaft sa wrong fluid. It just affects the clutch packs. Malamang may tama na yun shaft during manufacturing process. Buti nabali under warranty. Swerte ka pa rin.
    Quote Originally Posted by istan View Post
    true mas ok na nga naghintay ng 6mos kaysa naghintay ng 6mos tapos magbayad pa ng half a million pesos. kaya din naman siguro wala ako naging problema at in-approve nila relatively quickly repair under warranty
    Mga bossing when kaya ang schedule ng fuel filter change ng Fortuner Desiel 2016. 33k na ang odo ko.what about change of transmission oil?
    Aug 2014
    Quote Originally Posted by attyallanlatras View Post
    Mga bossing when kaya ang schedule ng fuel filter change ng Fortuner Desiel 2016. 33k na ang odo ko.what about change of transmission fue?
    Haggang maari Every change oil Bro palit ka. Magkano lang yung fuel Filter. Para iwas din sira sa Scv natin [emoji847]
    Sent from my SM-G965U using Tapatalk
    Mar 2005
    Sir at 25k nag palit na ko. Pero sobra linis pa at halos wala pa dumi. Nasanay kasi ako sa Santa Fe ko na every 20k palit fuel filter kasi mura lang yung Fuel Filter. Siguro at 50k kaya pa. BTW Unioil Guadalupe at Mindanao ave ako madalas nagpapa gas.
    Sep 2016
    Don't know how to post a pic from Toyota Fort Maintenance Schedule manual Australia but it says that FUEL Filter should be replace every 24months or 40,000km whichever comes first.
    For vehicles using fuel from non-commercial supplies, replace the fuel filter every 12months or 20,000 km whichever comes first.
    For transmission oil for both Manual and Automatic should be inspected by toyota service center every 24months or 40,000km whichever comes first.
    Under extreme conditions or driven in harsh environments Replace transmission oil for both manual and automatic every 24months or 40,000km whichever comes first.
    Extreme Conditions may includes:
    -Driving on rough, muddy and dusty roads.
    -Towing.
    -Extensive idling, low speed driving for long distance such as taxis.
    -Continuous high speed driving (at speeds greater than 140 km/h) for over 2 hours.
    -Using fuel from non-commercial supplies.
    Again this is base from Australia fortuner.
    Hindi ko alam if applicable sa atin dito sa Pilipinas, maybe yes.
    Regards.
    May PDF manual ako for both vehicle and maintenance kaso right handed eh, nevertheless same lang ata ung ibang. Pano ba mag share ng file dito?
    Convinient kasi kapag nasa phone nalang ang manual by the power of Searching button then hurray : )
    Quote Originally Posted by cristian ZDN View Post
    -Towing.
    Regards.
    Bro, can you pm me the pdf file?
    Dec 2009
    For the brake fluid..theres a tool which will tell you whether it's time to change it or not..its available at any online shopping platformscreenshot_20191120-094646_shopee.jpg
    di naman nito ma detect yun nasa lines and sa mismong banjo bolt, dito madalas yun corrosion and possible clog sa brake line
2016 Toyota Fortuner
