Page 140 of 156 FirstFirst ... 4090130136137138139140141142143144150 ... LastLast
Results 2,781 to 2,800 of 5286
    Jan 2014
    The suspension is firm which allows you to enter and exit corners faster than other PPV. The ride of the fortuner on par with my truck.
    Sent from my SM-A700FD using Tsikot Forums mobile app
    Jan 2014
    Iba padin riding comfort ng CUVs. Upgrading to aftermarket shocks would cost around 40 to 70k
    Nov 2017
    Quote Originally Posted by crosswind View Post
    Well if you can buy worth 2M SUV balewala lng yan[emoji1] for me[emoji111]
    Jan 2014
    Quote Originally Posted by maxpedition View Post
    Well I agree with you bro. But not all owners of 2m plus cars would consider it haha
    Sep 2017
    Malakas naman brakes ng 2016-2017 na fort kahit drum lang likod. Actually mas malakas pa siya compare sa sedan na quad disc brakes. Siguro may factor dun malaki na diameter ng disc sa harap ng fortuner.
    Jan 2014
    I don't feel the difference between the Fortuner v with drum brakes and the Mux with disc brakes maybe sa long downhill road ma fefeel
    Sent from my SM-A700FD using Tapatalk
    Nov 2017
    Sus pare parehas lang yan disc at drum basta importante kumakagat preno mo dati nga naka drum brake ka lang e buhay ka pa hanggng ngayon, kung hindi ka listo sa pagdrive kahit anung high tech auto mo malamang me paglalagyan ka
    Oct 2007
    +1000 on this.
    Sent from my ONEPLUS 5 using Tapatalk
    I think the advantage of disc brake is heat dissipation from heavy use and flooded streets... Water gets trapped inside drum brakes, hence dries longer.
    Will add that Disc brakes would give a shorter Stopping distance as compared to drum brakes.
    Although the difference will only be a few inches or centimeter, during emergency braking every small distance counts.
    Jul 2012
    and also disc brakes are easy to service, no need to be adjusted regularly like the drums
    Nov 2017
    Disc brake also prone to warping or uneven surface when using not compatible brake pad. I think both had pros and cons.
    Jul 2017
    mga sir tanong ko lang kung saan ang location ng engine number at chasis number ng all new gen ng fortuner..TIA
    Oct 2007
    Malakas ang preno ng fortuner ko kahit naka drum, minsan nga ayaw ko kasi malakas ang preno, di swabe.
    Nov 2007
    Wow mura sa aliexpress! 1.5k lang. may fb store nagbebenta ng 6.5k.
    Looking at olx, meron 2.6k lang. teckhowz name ng fb page.
    For voltmeter, got mine from amazon. Pero meron sa d3tech at maricel online.
    Nov 2007
    Mas maganda ang internal sensors for tpms but if hindi naman high risk areas pinupuntahan mo, ok na ang external sensors.
    Oct 2007
    Convenient pag may TPMS, I have one installed in my Mazda 3, type is installed inside the rim, maybe I'll have one installed sa fortuner also.
    Sent from my Nexus 7 using Tapatalk
    Nov 2017
    Nov 2017
    Foot pump nga hirap nako hanginan gulong ng kotse baka abutin ako half hour nun. Lakas ni papa walter[emoji4]
    Sep 2017
    Done 3rd pms, mga 7,900 din na bayaran lahat2x. Hehe.
2016 Toyota Fortuner
