Results 1 to 10 of 35
- Oct 2010
- 8
August 6th, 2011 09:54 AM #1Help ! Just bought a Toyota Altis 2003 1.6e, what should I do to keep it good running condition.
Thanks
August 6th, 2011 06:15 PM #2
First things first, do a general check-up and service. That would mean getting a tune-up, changing the oil, oil filter, fuel filter, air filter, brake fluid, gear oil (or ATF), and power steering fluid. Check your suspension, serpentine belt, get an alignment and have the brakes cleaned. Have the MAF sensor cleaned with electric contact cleaner just as well.
The Altis engine is also prone to sludging if the previous owner did not change it every 5,000kms so you can have the mechanic check your engine as well by opening the valve cover and doing a visual inspection.
May cost you a bit but heck, its worth the peace of mind and starting fresh with your new vehicle
- Oct 2010
- 8
August 7th, 2011 06:03 AM #3thanks a lot , follow up question, does it use a timing chain or belt?
Thanks again
August 8th, 2011 11:08 AM #4
Timing chain. As long as the oil is regularly changed (every 5000kms, no need for synthetic), the timing chain should also last.
- Oct 2010
- 8
August 10th, 2011 05:22 AM #5sir vinj, may ma recommend ba kayo na carshop dito sa area ng pasig for my altis, thanks
August 10th, 2011 02:46 PM #6
Try Servitek in Kapitolyo or Auto Camp, or Petron CCC near Auto Camp/ Home Depot (Across Meralco) along Ortigas Ave. if you're just doing the regular service.
- Oct 2010
- 8
August 13th, 2011 05:05 PM #7Mga Sir, how much kaya po ang drive belt tensioner, maingay na po kasi yung sa altis ko eh, thanks again
- Dec 2009
- 242
August 19th, 2011 02:54 PM #8Punta ka sa Toyota Pasig along C5 to inquire for the price of tensioner. I suggest buy the original because it's an engine part para sure ka na matibay.
- Aug 2011
- 1
- Oct 2010
- 8
August 24th, 2011 01:18 PM #10Mga Sir, Saan po kaya pwede ko pa clean yung MAF sensor ng car ko (2003 1.6e altis) ? I hear very sensitive daw po ito, Thanks
