Page 28 of 102 FirstFirst ... 182425262728293031323878 ... LastLast
Results 541 to 560 of 2033
    #541
    Quote Originally Posted by tanunoy View Post
    2014 Toyota Wigo 1.0G M/T
    One for the masses
    2014 Toyota Wigo 1.0G M/T - Honest Car Reviews Philippines
    I read through review above and checked out the pictures. Picture number #4 is of the sticker in the engine bay which contains "valve clearance" data, which I haven't seen in a new car for a very very long time.
    Does this mean that the valve clearances must be adjusted periodically like cars made before the turn of the millennium? Can the experts in this forum help with this question?
    Thanks in advance!
    Dec 2011
    #542
    Quote Originally Posted by bananatype View Post
    Thanks in advance!
    Yes, it needs to be adjusted. I have the 1KR-FE engine mechanical (pdf)file and...looks complicated. There are 8 main steps and on the fifth, you have to remove all 13bolts and 2nuts to remove the cylinder head cover.
    Oct 2013
    #543
    Thanks in advance!
    2NZ-FE user here... there is also a sticker to check and adjust if necessary the valve clearance * 80T KM
    #544
    Quote Originally Posted by Izzie View Post
    Thanks *Izzie for the reply. This engine seems to be a throwback to the 1990s -- no VVTi and manually adjusted valve tappet.
    Weird for a Toyota, but it explains why Wigo is so affordable. If you can wait an extra hour every periodic servicing, then I guess it won't really matter. It's just so retro though...
    Thanks again.
    Dec 2013
    #545
    Sad to say but I backed out na sa Wigo, maraming ng stock for the E variant but for the G variant my SA could still not give me an estimate date. I'll be getting my mirage na tomorrow, pero more power pa din to Wigo owners and wannabe owners here, I still think this car is a bang for the buck
    #546
    Sir consider din ang after sales service ng mitsubishi. I have heard and read a lot of horror stories about it. Actually, that is the same reason that is holding me back to buying a very good car (mirage).
    #547
    ^^^I am a vios owner, sadly dami ding casa na hindi lang walang wenta pero napakadorobo pa.
    Isa na ung nasa alabang. Ang baboy pa sa kotse.
    Posted via Tsikot Mobile App
    #548
    ang tgal nilang mag produce ng wigo at 1 month n ako intay kya mag mirage gls n lng ako
    volts73
    Dec 2013
    #549
    Quote Originally Posted by whitebishop View Post
    I have considered that na din sir don't worry, meron community mga mirage owners and they have contacts where to get cheap parts, accessories, good casa service etc hehe.. ayaw ko kasi matapos summer ng hindi na ipapasyal daughter ko, I promised her kasi that we would go on roadtrips this summer. Mejo lamang pa din talaga Wigo G over glx when it comes to safety features and accessories, engine lang talaga pampalubag ko sa glx ko, unti untiin ko nlang siguro upgrade, unahin ko muna alloy black rims and wider tires ;)
    #550
    ^if I may suggest sir para gumanda ang FC at umabot sa 14km/l on city lagyan mo ng rear spoiler. it reduces yung air drag.
    #551
    Quote Originally Posted by brainmafia_310 View Post
    totoo ba to? grabe dun pa naman nagpapa casa lagi ang kapatid ko kaya pala 3 years pa lang vios nya nag overheat na.
    #552
    well may iba nagsasabi na pag regular maintenance okay lang. meron din namang sablay daw. may nabasa din ako na wag mong iiwanan sa kanila yung kotse mo lalo na pag repair.
    ako kinuha ko kotse ko somewhere in q.ave. pero ni minsan hindi ako nagpaPMS sa kanila kasi nga i heard a lot of bad story sa kanila at the same time, sabalay ang tint at sabalay and undercoting ko - nakatatlo o apat ako ng balik ng tint sa kanila. until nagsawa na ako kasi yung cost of toll fee, traffic, stress plus gas eh mas mahala pa na ipafull tint ko sa v-kool yung vios ko kaakbalik sa kanila.
    so i decided to check yung nasa alabang kasi kung regular PMS lang - wala naman dapat problema.
    ampootah, pagbalik ng kotse ko ang dumi ng loob, bakas ng kamay dito at kung saan saan. sa toyota bicutan at dasma, pag nagpapagawa ka may initial checklist at ipapakita nila na ito yung exisiting tama ng kotse mo. tapos after the maintenane, pwede mo isaisahin yung pinagawa mo, in fact ipapakita pa nila sayo. pagbalik sayo ng kotse makikita mo na naka cover ung upuan at malinis na yung kotse. yung mga box may masking tape at may sign ng nagsara.
    like for regular oil change, pagbalik sayo ng kotse isstart nila with your SA. tapos papatayin makina then huhugutin oil dipstick para sigurado kang bago yung langis mo. bukod pa sa nakikita mo ito sa window.
    di na ako babalik dun. may nabasa din ako (di ko na makita at maalala kung saan, either sa tsikot or vcp or any other forums) na parang nagpa change oil siya diyan, and minarkahan yung oil filter. paglabas chineck niya hindi napalitan oil filter. same story dun sa nagpost na naka elantra.
    so sa tingin ko madami din horror stories sa casa ng toyota - ang advantage lang nito sa iba is, AFAIK and IMHO - mas madami kang choices na pwedeng puntahan hindi tulad ng iabng brand na masyadong malaki nasasakupan ng isang CASA nila.
    #553
    If you cant watch videos while driving, my friendly electrician can trick the monitor into thinking the parking brake is engaged. Just by tapping a wire in the dash. I guess there wont be warranty problems as everything looks the same afterwards. The system waits for a signal from the parkingbrake light. By changing over to a wire that is always powered, the system thinks the park brake is always engaged. Hehe. Just visit the jemson thread in the electrical forums if you need to find him.
    Anyway, the reason I posted is I want to ask how to make the navigation work. Where can I get the SD card and does it need an extra antenna also? The antenna can be sourced quite easily. Its the sd that im clueless about. No, i dont have a wigo. Just helping out a friend. Thank you sirs.
    #554
    Is there an interior trunk release button or lever? For those mall entrance inspections. Or does one have to turn off the engine and use the key topen the hatch?
    Feb 2014
    #555
    yes meron po
    Feb 2014
    #556
    pinalagyan ko ng side visor (kung yun ang tawag nga doon ) yun wigo, any idea po kung ano magandang pampunas, khit micro fiber cloth eh parang nagagasgas. tnx po10178208_10203672642962371_1405583375_n.jpg
    #557
    Pwede momsiya iwax ng car wax from time to time to protect and eliminate fine scratches. Nsame with the headlamps. Hehe
    Sep 2013
    #558
    Sir, I sent you a PM regarding the GPS navigation feature. Please check.
    Apr 2014
    #559
    Hi All,
    Sa mga nakakuha na nang wigo, may undercoat at rustproofing na ba by default ang wigo?
    Thanks!
    #560
    wala pa wigo 1 month na nagaantay.
2014 Toyota Wigo
