Page 198 of 205 FirstFirst ... 98148188194195196197198199200201202 ... LastLast
Results 1,971 to 1,980 of 2050
    Dec 2017
    #1971
    Just bought a brand new Wigo G AT and the AC starts having defects after 10 days (Car was not used daily).
    AC is not cooler that usual. After starting the car it blows cool air but after a couple mins it feels like it was set to Fan.
    I had my friends check it and they can't see any issues.
    Fanbelt is working fine same with compressor.
    Since it is bnew not sure if its with the Freon.
    (Most likely casa would know whats wrong)
    Any of you guys experienced this with bnew wigo?
    Thanks in advance.
    #1972
    Best time to return it to the casa for repair, habang bagong bago pa hehe.
    Dec 2017
    #1973
    Quote Originally Posted by mda View Post
    Goods parin ba kahit nagka issue na sa AC?
    Medyo nagka trust issue ako kay Wigo. Lol
    Bnew na nga nagka issue pa. What more pag tumagal na? Hindi kya prone na sya sa mga sira?
    Quote Originally Posted by kinoako View Post
    Thanks in advance.
    how did they find out na ok ang ac system?
    take your wigo to your dealership. they have procedures to isolate the problem.
    if there is no freon baka meron leak...theyll replace whichever part that needs replacing.
    #1975
    Thanks in advance.
    sounds like a freon leak.
    and since it is still under warranty, it is but logical to bring it to the casa for (free) repair.
    that is what warranty is for, po. for the "unforeseen defects".
    my wigo has been problem-free for three years since new.
    Feb 2014
    #1976
    Thanks in advance.
    check around the fittings for leaks. the refrigerant evaporates but the oil would weep. yes there's refrigerant+oil going through the system
    Jan 2018
    #1977
    ever since nabili ko si stealth my wigo wala pa ako naging problem sa car. engine support, aircon, wheel alignment, shock absorber and etc. last december 2016 ko nabili ang wigo g automatic first car ko sya and before nung nasa makati ako grabe gamit na gamit sa traffic mostly nararamdaman ko di masyado lumalamig pero dahil sa traffic at init ng panahon kaya madalas mas laspag pa daw ang sasakyan na babad sa traffic kesa dun sa malalayo ang tinatakbo kasi less stress sa engine then hindi madaling mag deteriorate ang engine oil. sa ngayon balik na ulit ako sa laguna nag wowork less traffic then malapit lang sa work tapos may lakad man ako na malayo eh nakakatakbo ng 100kph si stealth sa express unlike dati from hulo bliss to makati lang route ko pero ramdam ko stress ang engine. kasi malalaman mo gagaspang takbo nya once na naka idle lang sya matagal lalo na pag traffic.
    just sharing my experience having this car.
    engine is stressed at idle? says who? the vibration?
    engine isn't even revving to 5000 rpm,
    on idle its only making 10 or so hp this doesn't produce much heat to even hurt any oil.
    #1979
    bro kung average mo idle everyday is 1 hour. ok lang yun? frequent oil change helps?
    idling is fine, gagalaw naman diba youll cycle thru idle and mid power. ecu with its sensors is smart naman nowadays.
2014 Toyota Wigo
