Results 701 to 710 of 2050
- Feb 2014
- 47
June 16th, 2014 07:32 AM #701Thanks niky...light traffic xa...frst full tank ko to...city driving...sabi ng SA q hindi pa raw pwede i.above 60 ang speed..kasi break in period pa...mga aftr 1000 mileage pa pwede...mga nasa 20-30-40 lang speed q...city driving light traffic...sabi ng kuya q same ganyan dw fc nya sa avanza dapat raw mas efficient ang wigo kasi maliit engine...pero i was thinking baka dahil nasa 600 pa mileage ko and bago pa xa kaya Malakas sa gas...
Posted via Tsikot Mobile App
June 16th, 2014 11:02 AM #702
You can go over 60, just don't sustain the speed.
For break in, you want to vary your speed... don't stick to one cruising speed. And take it easy when it's cold.
Good luck with the car. You can probably improve the economy by learning how to "read" traffic... so you can lift off the gas pedal and coast when you know traffic is about to stop, or get out of a lane that is about to stop. Also, higher tire pressures should help economy a bit, especially in stop-go traffic where you're accelerating a lot.
- Feb 2014
- 47
June 17th, 2014 02:53 AM #703
- Feb 2014
- 47
June 17th, 2014 08:53 PM #704Fc update: naglong drive aq nasa 16.97 na xa...=) full tank pa rin hehehe
June 18th, 2014 09:38 PM #705
Mga sir, regarding driver's license, ano po ba ok na kunin? Prof or nonprof? And ung number 1 2 3 or ok na po ung 1 2?
- Apr 2010
- 268
June 18th, 2014 10:02 PM #706
- Aug 2012
- 2,767
June 18th, 2014 10:35 PM #707depends kung ano ida-drive mo..
PRO = for driving PUBLIC utility vehicles or driving for your earning
NON-PRO = for driving PRIVATE vehicles
Restrictions
1 = Motorcycle or Tricycle
2 = Vehicle up to 4500 kg (M/T)
3 = Vehicle over 4500 kg (M/T)
4 = Automatic clutch up to 4500 kg (A/T)
5 = Automatic clutch over 4500 kg (A/T)
6,7,8 = Articulated vehicles
if Wigo M/T ang ida-drive mo, get NON-PRO with Restriction "2"
if Wigo A/T ang ida-drive mo, get NON-PRO with Restriction "4"
if you can drive both M/T and A/T, get NON-PRO with Restriction "2, 4"
if you know how to drive a motorcycle, then add Restriction "1"
you do not need "3" or "5" as they are for heavy vehicles. even a Toyota Innova is less than 4,500 kg (Gross Weight)
Toyota Innova = 2,300 kg (Gross Weight)
June 19th, 2014 12:09 AM #709
Bat ka kukuha ng restriction 4 eh ang dali dali kumuha ng restriction 2. Wala pa kong nakikitang hindi nakarestriction 2.
Ako nga may restriction 1 din kahit hindi marunong magmotor. The LTO just gives it away anyway. But if you wanna be righteous about it, get restriction 2 and learn how to drive both AT and MT.
- Feb 2011
- 129
June 19th, 2014 04:21 AM #710to date, i've never seen a LTO license na may restriction 4. yung kasabayan ko kumuha ng license nun, she keep on insisting na automatic ang iddrive nya, LTO still gave her restriction 2. And it is true that at some LTO branches, they are giving away restriction 1.
lotus elise all the way! 2004 edition
Lotus returns...
