Hmmm. Meron na ba local pics?![]()
Matanong lang
Back when the old Hiace came, just the previous one, why did we, Filipinos, coined up the Grandia trim to the Hiace?
Hindi ko mahanap sa ibang bansa where Hiaces are sold. Does the Grandia trim name is the Hiace trim na talagang "Only in the Philippines?"![]()
Yep.
Sa Japan diba Super Custom. Nasakyan ko na pareho, mas matino at tahimik pa yung JDM than the local Grandia/ Super Grandia
May nakita pala akong facelifted Commuter kanina..
Pareho lang din ang itsura. Tapos yung rim caps pangit din. Tapos naka H4 bulbs parin?
O baka sa GL at Super Grandia lang naka Quad Beam?
Kahit 20s kaya din (and have been installed). But tama si vinj, don't stray from the load indicator/capacity of the stock tires so as not to compromise your loading capacity and damaging your tires and wheels.
Stock Grandia sizes are:
Super - 225/70r15
GL - 195/80r15
Putting them thru www.1010tires.com (look for the tire size calculator app), you'll get the ff:
16 - 215/70r16
17 - 215/65r17
These are available sizes locally. Or they should be, coz these are the tires of the Grand Starex. And if these tires can handle that weight, they can handle yours as well.
Nakakita ako kanina ng 2011 Super Grandia na kulay white sa may Robinsons Ermita..Nabago lang ang bumper nya at minor lang ang change sa design ng grille pero halos same din ng design a bit.Ang rims nya ay same din sa 2007-2010 Super Grandia.![]()
Saw one too before, Grandia siya. Silver. Panget IMO.![]()
Mas gusto ko pa yung pre-facelift, at least ... mas mura pa. Nyahaha.
Panget nga.
HiAce na nilagyan ng bumper ng Altis![]()
Sablay pa yung rim caps![]()
Deins ko gusto tail lights ng new Altis.
Front fascia pa siguro. Pero likod ...
Hilux at Fortuner pa. Nyahaha.
Pumangit yung wheel covers/hub caps na ginamit sa Commuter at GL Grandia at iisa nalang ang design na ginamit!Akala mo bolted sya ng screws/nuts sa rims-wheels pero di naman pala kaya madaling nakawin parin.
Most likely same engine parin yan kasi tinanong ko yung nagpapasada ng 2011 Hiace Commuter sa may Savemore sa may T.M Kalaw at 2.5 Liter D-4D parin ang Hiace nya.
Bat ba antipid nila sa mags. Milyon na yan di pa nila mabilhan ng mags. Hay Toyota. Kumusta kaya ang suspension para ka pa rin kayang sumakay sa jeep?
Based on my experience, after changing tires from stock to 215-70-r16, na lessen ung bumpy ride at nag stable sa mga turns, lumapad kz parang nag match sa body ng gl[/IMG]
