Results 1 to 10 of 65
December 18th, 2016 05:08 PM #1
Can I use dish soap to clean only K&N air filter without the kit cleaning? TIA
December 18th, 2016 06:07 PM #2
OT
Almost everything is disposable nowadays. Air filters of yesteryears were washable oil bath steel wool filled air filters then changed to dry paper element disposable folded accordion air filters. Now, back to washable air filters? Just like the pasador before the disposable sanitary napkins. Is technology going backwards?
December 18th, 2016 08:48 PM #3
December 18th, 2016 10:50 PM #4
pwede din ata if you use a mild kind of soap pero you need to oil it again w/ the k&n filter oil so might as well go w/ the cleaning kit na lang din
BANNED BANNED BANNED
- Jun 2007
- 122
December 18th, 2016 11:39 PM #5Non detergent based yung pang linis ng K&N. Hugsan mo lang, wag mo sabonin. Mahirap alisin detergent sa filter. Bilhan mo ng filter wrap para may damit yung filter mo.
December 19th, 2016 05:08 AM #6
If you were to dress a filter with a pseudo filter around it and oil the K&N filter, consider the restriction it will give your air induction system. It would put this indicator on the red all the time
air filter restriction indicator - Google Search
- Jan 2013
- 686
December 19th, 2016 09:38 AM #7I only use joy dishwashing liquid. Pabulain yung joy sa timbang may tubig just enough para dun knn air filter then babad for 30 minutes to 1 hour then banlaw ng maigi.
Then patuyuin but wag na wag ibiliad sa araw. Then apply singer oil. Good to go ulit.
So far 4 years na and still looks and performs as brand new.
December 19th, 2016 09:52 AM #8
Not meaning to spark a debate. I'm just airing an opinion and I fully respect peoples' decision for using or not using K&N filters.
Apparently it seems, that K&N filters, by nature of them being reusable, do save you a bit of money that would otherwise be spent on throw-away paper filters. But is it really lowering TCO? Is it providing better filtration?
Honestly, I haven't used them. I have considered using K&N filters but decided against it. I view them as performance drop-in parts that may marginally increase airflow but at the expense (it seems) of filtration ability. In my head, they're more adept at motorsports where engine performance is paramount while engine reliability and longevity takes a back seat. But for any other types of driving, especially daily-driven vehicles, OEM filters, to me, appears to be the better choice.
K&N Air Filter Review - Debunking the Myths (and why OEM is better)
- Oct 2015
- 1,054
December 19th, 2016 10:30 AM #9^
I've posted the same concerns re: oiled filters several times on this board. It is also discussed at length in various forums. Not just K&N but most other aftermarket CAI as well. Another major concern aside from filtration ability is the possibility of loose oil being deposited onto your MAF sensor, eventually destroying it.
This is another good resource:
"Cold-air intakes" and "high-flow air filter" FAQ - TDIClub Forums
Not really trying to dissuade people from using it as well, I just hope people who use it are better informed of the potential risks.
December 21st, 2016 06:49 AM #10
Just a thought:
If you don't mind the intake noise, why not place the air intake next to the evaporator inside the car. 1. For cleaner air quality- the same air you would be breathing, 2. With the air conditioner on, the intake air temperature would be colder and more dense.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
