Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 63
    #41
    ^^paki sagot naman 'to
    tsaka is it true that when you go fully synthetic, you don't have to change your oil as much as, say when your on semi-synthetic oil and on mineral blend of oil?
    #42
    Feb 2003
    #43
    is there a valvoline 15w-50? can't seem to find any info on the web...
    Aug 2006
    #44
    Quote Originally Posted by baludoy
    blend of oil?
    If you use fully synthetic, You can change the oil between 5,000-10,000 miles (it depends on car model)Most modern car here in the US recommend 10,000 miles before changing the oils,But i don't follow that because oil is cheaper than the engine.
    #45
    Quote Originally Posted by hagiber View Post
    May alam ba kayong 5W20 na oil ? Ito yung nakalagay sa oil cap nang Escape and ito yung recommended weight sa manual. Wala pa akong makita so far, yung closest siguro is the Havoline Energy Synthetic but I was wondering baka may exactong 5W20...
    ito yong recommended ng Honda, Chrysler atbp.. Ito rin yong ginagamit ko sa Honda Pilot ko ( mobil fully sync 5w - 20 )
    #46
    Quote Originally Posted by chicane811 View Post
    Anybody heard about Amsoil? Have you seen it around and where can we buy it?
    A lot of STI owners been using this...and all praises.
    #47
    advise naman please. i just recently changed oil on my lancer, from semi-synthetic to fully synthetic. car is 2002 model, only 30000 km on the odo. i pride myself before of having a pretty high km/l mileage, 11+ km/l city and up to 15 km/l highway (on semi-synthetic oil). actually before when i had it on pure mineral oil the mileage was even higher, 12+km/l city and 16+ km/l highway. i did not mind the slight drop in mileage when i switched to semi-synthetic since i was thinking of the added protection the engine will get. but now after changing oil to fully synthetic (shell ultra yata yun) my mileage dropped to only 6km/l city. i have not tested it on the highway yet as i had not had the chance. driving conditions are the same as before, no change in driving habits either. could this be due to the oil?
    any comments will be appreciated. thanks.
    this is like using a premium gas= higher performance = low mileage.
    Oct 2005
    #48
    Quote Originally Posted by jardeus View Post
    Oil Name : Mobil 1
    Blend : Supersynthetic
    Rating :
    Viscosity : 0w-40
    Retail Price : P550/ liter ===>sakin 330 pesos per litre (sealed)
    Recommended for what types of Gasoline Ride: All (specially for tropical countries) (approved by Mercedes_benz, BMW, Volkswagen, Toyota etc...
    just contact me by this number +639193514579
    available in metro manila only...
    remeber 330 pesos lang per litre... underground economy toh.. pinapaubos ko lang....
    sa ACE 600+ ang isa nito....
    sakin 330 pesos lang... 330, 330, 330, 330, 330, 330, 330, 330,.............................................. .................................................. ..........................
    Sir, Ano ba ang expiry date ng engine oil mo ?? Thanks
    #49
    as part of your pms, do you guys also change your oilpan too? if you do or if we are supposed to, at what intervals?
    #50
    can u give me ur input regarding sa oil na regular, like 20w/40 like the most basic of all oils yung hindi pa multigrade...
    #51
    Quote Originally Posted by joseph_abri View Post
    monograde ba kamo? usually SAE 10 to 40. Since designated for specific short temp. ranges lang siya. Eto:
    GRADE: Ambient Temp. in (C)
    SAE 10 = -20 to -5
    SAE 20 = -10 to 10
    SAE 30 = 0 to 30
    SAE 40 = 20 to 40 <= best suit for our tropical climate
    May 2007
    #52
    meron ba ditong gumagamit ng mobil super xhp? any comment regarding this brand of oil?
    #53
    mga peeps,
    try nyo motul htec 100, i am using it in turbo and non turbo diesel engine and also in gasoline engines. its better for me compared to mobil 1 and its cheaper.
    #54
    Just want to share this link.. aside from shell website mobile1 had software tool in identifying the right oil for new and old cars..
    http://www.mobiloil.com/USA-English/....aspx?option=2
    Not for anything else, I just thought this woul be of great help for those who are researching for the right viscosity.
    Maybe you can check and find similar oils regardles of the brand out in the market.
    Please disregard if previous post have been done..
    Thanks
    #55
    oo nga, ano maganda o dapat na oil for a nissan sentra 1196 ex saloon? la na aksi yung manual nung nagbenta sakin e, thanks.
    #56
    Quote Originally Posted by jackaroo View Post
    Oil Name : Conoco
    Blend : Fully Synthetic
    Rating : Api SL/CF, Acea A3
    Viscosity : 5w50
    Retail Price : P1250/Gal or P313/L
    This is a new brand in the Phil but from a known maker in the US. Actual products sourced from singapore plant. Also known for their hydrocracked mineral oils.
    Sir:
    Saan po makabili ng conoco? nag check kasi ako sa website nila, wala local dealer sa Philippines.
    Tnx po!
    #57
    Quote Originally Posted by rallyrick View Post
    Mga Dudes
    don't use fancy oils and additives just follow your vehicles recommended oil spec. and better clean your internal engine with dtxfr first before change your oil and filters to remove micro hard carbon and sticky thick oils stock inside oil passage orifice. to prolong your engine services save lot of money . . trouble.
    more details: soon!!
    I agree. Pero caution lang sa pag gamit ng oil additives and engine flush. They may do some serious damage to your rubber seals...
    :naughty2:
    #58
    Mga sirs, tanong ko lang po kung ilang liter ng oil ang kailangan para sa Nissan GA16DE engine kapag magpapa change oil? Anong oil grade/viscosity po kaya ang recommended para dito? Aling brand din po kaya ang may mas effective na cleaning power? My car's milage is at 112,000 kms. Any feedback na rin po mula sa mga nakagamit na ng Shell Helix Super tungkol sa performance nito?
    Thanks po.
    Oct 2007
    #59
    Mga sirs, tanong lang po? meron bang kinalaman ang dulas ng oil sa quality nito? at kung meron ano ang pinakamaganda? Kc po meron akong makitang napakadulas na produkto. Salamat po.
    Feb 2007
    #60
    Oil Name : Vaico 60-0012
    Blend : HC Synthetic (Higher Grade to Semi Synthetic)
    Rating : ACEA A3, B3, API SL, CF
    Viscosity : SAE 10w-40
    Retail Price : Php 1600 1 galloon (5 Liters); and P350 per 1 Liter
    Recommended: Gas and Diesel Engines (Turbo and Normal Aspirated). And for the following Auto manufacturer code BMW (Long-98, Long 01, Long 01 FE); Ford (913-A, 913-B, 917-A, 912-A1); Mercedes Benz (227.0, 228.1, 229.1, 229.3, 229.31, 229.5); Opel (A-025, B-025); Volkswagen and Audi (502 00, 505 00, 505 01, 503 00, 503 01, 506 00, 506 01, 507 00)
    If you're interested, just text or call me at 09177448113. Vaico Oils are Genuine Made and Packed in GERMANY.
    Thank you.
    Jay C.
    09177448113
Oil Specification and Price Database for Gasoline Engines
