Page 1 of 3 123 LastLast
Results 1 to 20 of 63
    this was started by sir marwen in Trucks, SUV's, AUV's, and Anything and Everything Diesel Oil Specification and Price Database for Diesel Engines
    for the benefit of motorists with Gasoline Engines umpisahan ko na rin po rito...
    Oil Name : Oil Brand Name/Type and Company
    Blend : Mineral, Semi-Synth, Fully Synth
    Rating : Oil Rating
    Viscosity : xxWxx
    Retail Price : Pxxx.xx
    Recommended for what types of Gasoline Ride: Civic, Lancer, Altis, Lynx, etc.
    Oil Name : Caltex HavolineŽ Fully Synthetic
    Blend : Fully Synthetic
    Rating : API SL, SJ and SH, ACEA A3-02
    Viscosity : SAE 5W-40
    Retail Price : Php 2050-2200 per gallon
    Recommended for naturally aspirated and turbocharged gasoline and diesel engines in passenger cars and light commercial vehicles. For gas-fueled (natural gas and lpg)spark ingition engines where conventional passenger car motor oils are recommended.
    Oil Name : Caltex HavolineŽ Energy Synthetic
    Blend: Fully Synthetic
    Rating : API SL, SJ and SH, ILSAC GF-3, ACEA A1-02, B1-02, API Energy Conserving motor oil, Ford Jaguar WSS-M2C913-B, WSS-M2C912-A1
    Viscosity : SAE 5W-30
    Retail Price : Php 1140-1250 per gallon
    Oil Name : Caltex HavolineŽ Formula
    Blend: Mineral
    Rating: API SL, SJ or SH, SG, SF, API CF , CCMC G4
    Viscosity : SAE 20W-50
    Retail Price : Php 500-600 per gallon
    http://caltexoils.com
    share naman kayo dyan
    sir di ba recommended sa climate natin at least 15w-40
    you can safely use engine oils with viscosities mentioned above
    if you take a look at your car's manual pasok yan lahat... :mrgreen:
    Jan 1970
    mga sir, pwede ba malaman ano ibig sabihin ng xxWxx...
    pag mas mataas ung mas naunang xx ano ibig sabihin?
    pag mas mataas ung nahuling xx, ano naman ibig sabihin?
    mas mababa ba xx mas maganda???
    sir nick click on the links below:
    engine oil bible
    more info
    Dec 2002
    Oil Name : Citgo Supergard
    Blend : Mineral
    Rating : API SL/SJ
    Viscosity : 10w30, 10w40, 20w50
    Retail Price : P65-75/quart- Price Smart
    Recommended for what types of Gasoline Ride: Check your manual for recommended viscosities
    Oil Name : Mobil 1
    Rating : Api SL/SJ/CF
    Viscosity : 5w50
    Retail Price : P450-500/ liter
    Recommended for what types of Gasoline Ride: All
    Apr 2005
    Quote Originally Posted by jackaroo
    Blend : Mineral
    Rating : API SL/SJ
    Oil Name : Mobil 1
    Viscosity : 5w50
    Oil Name : Mobil 1
    Blend : Supersynthetic
    Rating :
    Viscosity : 0w-40
    Retail Price : P550/ liter ===>sakin 330 pesos per litre (sealed)
    Recommended for what types of Gasoline Ride: All (specially for tropical countries) (approved by Mercedes_benz, BMW, Volkswagen, Toyota etc...
    just contact me by this number +639193514579
    available in metro manila only...
    remeber 330 pesos lang per litre... underground economy toh.. pinapaubos ko lang....
    sa ACE 600+ ang isa nito....
    sakin 330 pesos lang... 330, 330, 330, 330, 330, 330, 330, 330,.............................................. .................................................. ..........................
    Oct 2005
    Quote Originally Posted by jardeus View Post
    Oil Name : Mobil 1
    Rating :
    Viscosity : 0w-40
    Sir, Ano ba ang expiry date ng engine oil mo ?? Thanks
    as part of your pms, do you guys also change your oilpan too? if you do or if we are supposed to, at what intervals?
    can u give me ur input regarding sa oil na regular, like 20w/40 like the most basic of all oils yung hindi pa multigrade...
    Jan 1970
    xxW/xx ba kamo? <--- viscosity ng lube yan.
    xxW ---> winter grade
    xx ---> summer grade
    pag mas mababa ang vicosity ng lube (ex. 10w/40 or 0w/30) mas malabnaw yung oil.
    nagkakatalo lang naman yan mga yan during engine start-up e. pag malabnaw kasi oil, mas okay yung fluidity niya inside the engine, therefore mas mabilis siya mag-circulate... not unlike yung malapot na oil, magstart siya mag-circulate sa engine kapag mainit na yun makina mo.
    yun ang pagkakaalam ko....
    tama ba?
    i suggest you still follow your car's manual regarding what oil or viscosity to use.
    Oil Name : Petron Ultron Touring
    Blend : Mineral
    Rating : API SL
    Viscosity : 20W50
    Retail Price : P115
    Recommended for what types of Gasoline Ride: Civic, Lancer, Altis, Lynx, and diesels.
    Oil Name : Castrol GTX
    Blend : Mineral,
    Rating : 20W-50
    Viscosity : API SL/CF
    Retail Price : P130
    Oil Name : Shell Helix Super
    Blend : Mineral
    Rating : API SJ
    Viscosity : 20W-50
    Retail Price : P120
    Apr 2005
    Sir/s,
    Anu po ba recommended oil for a civic?
    is there any bad efffect if you go fully synthetic currently then use mineral on next change oil?
    Quote Originally Posted by scooby91
    Sir/s,
    Just check the factory specification for your car. Usually mineral based motor oils will provide good enough protection under normal driving. Full synthetic oils give slightly better protection, especially against heat related oil-breakdown, but this is more applicable to turbo-charged engines or heavy modified n/a engines.
    Jan 1970
    May alam ba kayong 5W20 na oil ? Ito yung nakalagay sa oil cap nang Escape and ito yung recommended weight sa manual. Wala pa akong makita so far, yung closest siguro is the Havoline Energy Synthetic but I was wondering baka may exactong 5W20...
    Quote Originally Posted by hagiber View Post
    ito yong recommended ng Honda, Chrysler atbp.. Ito rin yong ginagamit ko sa Honda Pilot ko ( mobil fully sync 5w - 20 )
    Hmm...mukhang sobra labnao ng 5W-20. Parang flushing oil... Anyway if this is the recommended oil then go for the synthetic Havoline Energy. If not then the oil used sa casa is also good. Take a look sa manual ng Escape mo for other recommended SAE viscosity.
Oil Specification and Price Database for Gasoline Engines
