Results 1 to 10 of 15
January 29th, 2007 12:24 AM #1
***Selected Pages Only***
Click on links for full size images
Underhood Label:
http://tsikot.yehey.com/gallery/show...hp?photo=16221
What it says:
VEHICLE MAINTENANCE DATA DIESEL ENGINE
Engine Oil Use approved oil by MB Sheet 227.1 or 228.3
Or API CE or above grade oil
Oil viscosity refer to MB Sheet 224
Change Oil after the first 1,000km and every 10,000km running
(Check often oil level and refill when necessary)
T/A (transaxle) oil Use approved oil by MB Sheet 235.1
Change oil every 60,000km running
Oil Filter Change element after the first 1,000km and every 10,000km running
Fuel Filter and Pre Filter Change cartrige every 40,000km running
Air Cleaner On road, clean element every 10,000km running
Change element every 40,000km running
Off road, clean or change element after inspection frequently
http://tsikot.yehey.com/gallery/show...hp?photo=16219
http://tsikot.yehey.com/gallery/show...hp?photo=16220
http://tsikot.yehey.com/gallery/show...hp?photo=16213
http://tsikot.yehey.com/gallery/show...hp?photo=16214Last edited by OTEP; January 29th, 2007 at 01:15 AM.
January 29th, 2007 12:39 AM #2
January 29th, 2007 12:50 AM #3
January 29th, 2007 01:04 AM #4
January 29th, 2007 01:18 AM #5
- Jul 2007
- 345
August 4th, 2007 06:24 PM #6great sir, baka pwede ko sir ma-pa-photo copy manual nyo sir. may na bili kasi ako mb100, wala kasama na manual e. ma-DIY kasi ako, and a manual will be a great help. ty sir.
- Jul 2007
- 345
- Jul 2007
- 345
- Feb 2008
- 3
February 3rd, 2008 08:14 PM #9Last year on the month of September, I replaced the oil seal of the engine's transmission gear of my MB 100 van. By removing the worn out oil seal and installing the new, gear oil spill out naturally. After the installation was done, the mechanic has just filled it up only 1 liter of gear oil. Is it enough? Or I have to fill up more gear oil again? How many liters more of gear oil should I refill?
February 4th, 2008 10:17 AM #10
galing talaga ni sir otep??
salamat sa info lalo na sa mgha fuse guide hindi kasi ako koreano para mabasa fuise gide ng mb ko
Yeah decorative bollard. A proper one is supposed to stop even a heavy truck. Apparently the ones...
