Results 41 to 50 of 108
- Aug 2017
- 2
August 23rd, 2017 09:51 PM #41Magandang araw po sa lahat, hingi lang po ng payo kabibili ko lang ng 2012 suzuki celerio for city driving pero nagkaka problema po ako sa 1st gear acceleration ko umaabot ako ng 3500 to4500 rpm bago uusad ang celerio lalo na pag may paakyat kahit sa humps o kaya sa trafic light naiiwan ako ng 20 meters puro busina abot ko meron po ba akong aayosin ? Salamat po in advance sa makakatulong ng advise.
- 52,731
- Aug 2017
- 2
August 24th, 2017 09:48 PM #43
- 52,731
August 24th, 2017 10:54 PM #44
- Aug 2017
- 5
August 30th, 2017 05:41 PM #456 days ago, our Celerio 2016 model's a/c broke down. The car is barely 2yrs old and ran 70k. We went to SOLID since it's not anymore under warranty. They found out that the evaporator is clean and clear, but it has a hole on the part where the foam is glued on. SOLID tried to weld the oart, but ut's so thin that it just melts away upon contact with heat. The problem now is that we can't find an evaporator for our car. Suzuki San Fdo doesn't have one either. PLEASE HELP!!!!
August 30th, 2017 06:36 PM #46
Try asking for other suzuki casa. Per order basis ata yan.
Also, why is it not under warranty?
August 30th, 2017 07:16 PM #47
- Aug 2017
- 5
- Aug 2017
- 5
August 30th, 2017 07:20 PM #49
August 30th, 2017 07:56 PM #50
high idle RPM at engine start
