hi to all..
i'm udj, from malaysia.I'm planning to buy an apv 1.6GLX A/T for my next project car, since before this i have a not-so-heavily mod Landy. I've tested the apv before and 'm in love with it..!
I read a few articles in apvclub.com, otomotif.com and a few other website (mostly written in indonesian accent) and i just can understand a few words..(eventhough i watch most of the Sinetron in Malaysia..
So, the point is, i'm searching for methods of lowering the car and put in bigger wheels. planning on putting an 18" rolling stock and 75mm drop down.
1. if i do an adjustable suspension (front) using the original absorber, do i need to cut the centre rod or otherwise will it hit the bottom of the absorber housing?
2. is it advisable to cut the spring?
Never cut springs
3. how to modify a leaf spring to make the car lower? i heard there's a few methods such as putting a block between the leaf and axle, using a short damper etc can anyone suggest me the advisable method without sacrifying too much ride comfort?
Use a lowering block
4. For bigger wheels (17"-20") what is the best width to fit under the fender? is it just plug and play? or do i need to put spacer?
5. The ground clearance for an A/T is 170mm (oil pan) as stated in the brochure. Once the car lowered uing 18" wheels, will the oil pan scrap the road/bumps?
That's the price you pay for lowering a vehicle
what if it does, is there any incoming major problems regarding the oil pan?
That depends on how you drive and if you catch the drain plug on something to rip it out
6. is there any ready-made adjustable suspension or leaf spring for apv sold in indonesia that i can buy n just plug n play?
7. any website reference?
Google is your friend
ur ideas will be appreciated. Thanks in advance.
APV rocks!
