Results 1 to 10 of 10
- Jul 2015
- 59
October 14th, 2015 09:33 AM #1Hi guys, just wanna ask for opinion regarding my problem. Kapag dumadaan po ako sa skyway or Roxas Blvd, lalo na kung mabilis po ang takbo, may maririnig na parang umuugong sa may baba ng sasakyan, kala ko tuloy parang ugong ng eroplano ang tunog. Hindi po ba na asphalto po yun mga cemento sa skyway at roxas blvd? Kapag sa mga mas maliit na daan, normally wala naman pong tunog or ugong sa ilalim.
Sabi ng isang friend ko baka daw po may sira yun wheel bearing sa gulong. Possible po kaya ito? Ano pa po kayang ibang possibleng sanhi ng tunog. Nagpacheck na po ako ng muffler, kala ko dati may butas pero wala naman daw pong butas or any problem with my muffler. If ever po wheel bearing ang problem nito? Mga magkano po kaya ang parts at labor nito at saan po kaya pwede pagawa? I'm thinking baka pwede sa servitek.
Any opinion will be greatly appreciated. Thanks.
Car: Toyota Altis 1.6G 2003 model
- Oct 2006
- 6,250
October 14th, 2015 09:44 AM #3
Possibly wheel bearing if it's not the tyres. For the rear wheel bearing, that is an assembly usually and for the front, it's a bearing and has to be repacked. If it needs replacement, buy the Aisin or Koyo brands which are cheaper than original Toyota but are similar to OEM spec as they also manufacture for OEM applications. The rear wheel bearing can be pricey and don't forget to specify that your car has ABS so the proper part is quoted if ever.
Servitek can check it for you and if you have to replace parts, best to buy it on your own so it will come out cheaper. In my case, i usually buy my Toyota parts from Toyorama in Banawe.Last edited by vinj; October 14th, 2015 at 09:48 AM.
October 14th, 2015 09:46 AM #4
huwag ka dumaan sa asphalt hehehe!
pa-repack mo muna ng grease ang wheel bearings mo baka kulang lang sa grasa. mura lang yan basta avoid shops na notorious sa sadyang paninira ng sasakyan at baka pagkatapos e magkaron ng aberya kahit wala naman. search mo dito sa tsikot ano yung shops to avoid.
- Jul 2015
- 59
October 14th, 2015 10:06 AM #5Hi sir. when you say repack of wheel bearing, meaning ba nito is irerepair lang by putting some grease on the wheel bearing? Mura lang po siguro kung repack lang right? Papacheck ko na lang sa servitek if it needs replacement or repack lang. Mas okay if repack na lang para hindi ako mapagastos ng malaki.
If ever po hindi sa wheel bearing ang problem, at sabi nyo possible sa gulong mismo. Ano po pwedeng sira ng gulong? Meaning papalitan ba buong gulong? Thanks.
- Jul 2015
- 59
October 14th, 2015 10:10 AM #6
- Oct 2006
- 6,250
October 14th, 2015 01:54 PM #7Yung harap, nare-repack, pero alam ko yung likod, pinapalitan ng buo.
October 14th, 2015 03:42 PM #8
LOL. Parang yung dentista ko last week. Nagreklamo yung isang pasyente na suamsakit yung ngipin niya pag nag-totoohbrush. Sabi ni Doc, "Huwag ka nalang mag toothbrush... solve diba?"
Re. sa tyres, some tyre models become noisy as they wear down. You can determine this by placing the car on lifters at the shop and spinning the wheels. Maririnig ng mekaniko kung bearing ang problema.
- Jul 2003
- 573
October 28th, 2015 03:58 AM #9sa pagkaka-alam ko, ang front wheel drive car, sealed bearing, hindi nare-repack yan. kung bearing nga problem, dinadala sa machine shop wheel hub para tanggalin bearing at palitan ng bago.
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
