Results 71 to 80 of 93
June 22nd, 2022 07:43 PM #71
Put adhesive rubber as stopper so the stem doesn't flex at high speeds. Problem solved....
June 23rd, 2022 07:10 AM #72
UPDATE: Medyo nag-stabilize na yung mga sensors. Still yung fronts, one is off by 2psi at yung isa ay by 2.5psi naman.
Yung mga temp readings not sure din kung accurate. Malamig naman kagabi pero parang mataas ang temps indicated.
Iniwan ko sa ibabaw ng dashboard yung base unit kahapon para sana mag-charge via solar.
Maybe not a good idea. Ang init nung unit which may not bode well for the batteries and the display.
Di rin naman gaanong nag-charge in that 4 hours or so na exposed directly sa sunlight.
So sinaksak ko na lang sa charger via micro USB until mag-fully charged.
Meron akong ganyan gagamitin ko nga sana as rubber feet nung base unit.
Kaso yung adhesive natuyo na yata kaya ayaw na dumikit.
I was thinking sana of using silicone sealant to build up around the valve stem.
- 52,731
June 23rd, 2022 07:29 AM #73
June 23rd, 2022 12:55 PM #74
dr.d... I have a digital tire pressure gauge I have been using for quite a while.
I have compared it with the reading of my digital air pump saka from various air station din ng mga gasolinahan.
I could say mga nasa +/-0.5 to 1psi lang naman differences nila, so it's good enough, relatively speaking.
Basta at around 34 psi it gets quite rough riding na so I try to maintain it between 30~33 psi lang.
Eto lang Falken na nakuha ko sa talagang rough road na nag-manifest yung matagtag so I had it sana at 35psi.
Right now, I'm observing pa kung pwede na sa all around yung 34psi ko sa fronts. Rears are maintained at 32 psi.
June 23rd, 2022 02:52 PM #75
Sir oj88. Where did you get the adhesive rubber? TIA.
Sent from my RMX3366 using Tsikot Forums mobile app
June 23rd, 2022 03:10 PM #76
Ace Hardware sa mga SM stores would have that. 3M ang brand, may kamahalan lang.
Mine isn't 3M kaya after a while in storage nawala na efficacy nung adhesive.
June 23rd, 2022 03:23 PM #77
Thanks gearhead000.
June 29th, 2022 02:34 PM #78
After about 6-8 weeks, the cold tire pressures were down to their minimums.
Aired them up to 35 psi (using Accutire MS-4020 tire gauge) and the TPMS reflected the pressure accurately. Without the decimal figures (which is not necessary anyway), I can only guesstimate that the tire gauge and the TPMS are likely only off by a few tenths of a psi. Not bad.
June 30th, 2022 01:41 AM #79
- Jun 2015
- 2,751
June 30th, 2022 10:39 AM #80How about tire valve stem sleeves? Not sure if these'll fit or if, since it's made of plastic, it won't flex.
https://shopee.ph/Stylish-Tire-Stem-...e-ac765f780d78
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
