Results 11 to 20 of 21
- 19
November 6th, 2002 09:10 PM #11zildj,
npa install ko na sa ac delco sa may timog....sis company rin sila ng midas.....i decided na ndi na lang lagyan ng damper coz bka pasukin lang ng tubig and in the long run kalawangin din....dat's just for me....til r next transaction...harap naman. :roll::roll:
- Nov 2002
- 50
November 7th, 2002 10:24 AM #12Kishyn... If you're talking about dampers/rubber bushings between the struts and springs, ok lang yon. Actually it's a must, kundi magiging maingay suspension mo. Ok lang rin yung bump stop na pinapasok sa cylinder ng strut to prevent it from bottoming out. Di naman nakaka-promote ng rust itong mga ito. Yung paglagay lang ng hose to insulate the springs and delikado dahil nga this can trap and gather water.
- 237
November 7th, 2002 10:53 AM #13Originally Posted by saintluci
what if mangyari ung sinabi dito sa thread na mapasukan ng tuubig?
any alternatiuves?
- Nov 2002
- 50
November 7th, 2002 01:19 PM #14If you can get hold of those insulators that are really meant to wrap springs, ok yon. As long as it's tight and hapet talaga para walang place for water to creep in, ok na siguro yon. Yung garden hose kse hindi mo naman pwede ipa-hapet sa springs yun eh, kse medyo hard plastic siya.
- 290
November 7th, 2002 02:27 PM #15tama si Kidd... yung rubber na nilalatag sa saluan ng spring bago ilapat ang spring ay importante at required.
kishyn, i'm assuming that you are referring to the hose thing not the one that is designed to fit into the spring holder.
- 14
- 237
November 11th, 2002 07:12 PM #17mga sir
simple lang ba mag install ng shocks/springs?
kasi sabi ng driver namin madali lang naman daw magkalas...kaya im thinking na instead of bringing it sa mga shops...dito na lang sa amin para tipid labor....
November 11th, 2002 11:53 PM #18
meleagant8,
be sure na safe pag dismantle mo ng springs. delikado yun. nakakamatay yun pag tumama sa yo yung springs when released from tension.
- 290
November 12th, 2002 11:10 AM #19meleagant8, if you have the proper tools to use and knows the correct orientation of spring when seated on the holder kaya siguro. pero if first time nyo pareho eh siguradong mahirapan kayo. pag-baklas ingat lang, pag-lagay ng spring pabalik eh kailangan pa ng pang compress dahil kapag wala eh siguradong mahihirapan kayong isalpak.
- 12
November 12th, 2002 11:28 AM #20pa install mo na lang para sigurado and tignan mo na lang kung papano para next time eh me idean na kayo. tyre pro sa United street sa Pasig Kapitolyo mura lang. o kaya sa Servitek same street isa lang me ari
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
