Results 1 to 10 of 10
March 8th, 2011 12:18 PM #1
May L300 kami na ginagamit for water delivery. Sa bigat ng load, less than a year napupudpod na tires (185R14).
May nag-recommend na gamitan ng tires with interior. Eto yung mga pinakita ng shops. 6.5x14 ang size (slightly bigger than stock)
Eto mas mura, parang pang truck/bus.
Eto mas mahal, halos doble presyo. "Lug type" or "Kargador" ang tawag nila. Mas ok daw 'to, pero diba pang off-road ang thread pattern nito? Worth it kaya ito? Siguro yung kapal nalang ng tread ang advantage nito.
- Apr 2010
- 38
March 8th, 2011 01:29 PM #2What brand of tires are you using? I also have an L300 and using the same 185R14 size tires but not using it to haul heavy stuff. Anyway I noticed that Bridgestones or the local Goodyears last longer than those made in India or China.
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 10th, 2011 08:35 AM #31. have your suspension checked. Most tire problems are caused by suspension problems.
2. AFAIK, Lug type tires are for off road use. You can use them but they are more expensive and dont really last longer than normal tires.
March 10th, 2011 10:57 AM #4
pwede siguro yung pang off road na gulong. yung bridgestone na brand yata maganda. =)
March 11th, 2011 10:32 AM #6
Thank you sa replies.
Yung 1st pic RIB TYPE pala tawag. Siguro yun muna susubukan ko.
Napaisip lang ako dun sa lug type kasi "kargador" tawag nila. Tapos kapal pa ng tread (pero baka nga ganun din lifespan kung softer compound ang ginamit- just like the Mud Tires for 4x4).
I've shifted to Indonesian/Korean/Thai? tires sa lahat ng cars namin (Nexxen, Kenda, Nankang, Gajah) happy naman ako. Dito lang talaga sa pang kargahan namin ako nagkaka-problema.
Ok naman suspension, nakabantay ako dun kasi lagi kargado.
March 14th, 2011 03:30 PM #7
* nic
kamusta naman yung molye and shock absorber?
nag dagdag ka ng molye?
nagpalit ka na rin ng shock absorber? what brand?
- Apr 2010
- 38
March 15th, 2011 06:44 PM #8I guess at the end of the day, since mabigat talaga load ng van mo, your tires would really not last long regardless of type or brand. The issue you raised naman is about lifespan and not about your tires blowing up due to the heavy load. For safety reasons I guess sticking to you 8 ply 185R14s would be logical.
- Apr 2010
- 38
March 15th, 2011 07:49 PM #9I guess at the end of the day, since mabigat talaga load ng van mo, your tires would really not last long regardless of type or brand. The issue you raised naman is about lifespan and not about your tires blowing up due to the heavy load. For safety reasons I guess sticking to you 8 ply 185R14s would be logical.
March 15th, 2011 09:18 PM #10
Yung 6.50x14 bias construction yun, low mileage compared to radials. Madali kasing uminit yan lalo na kung kargado at mabilis ang takbo. Even if you could find a radial with a lug type tread mas mabilis pa rin uminit yung compared to radial na rib type treads. Unless you only use the van at low speed and short trips kulang pa yung matitipid mo sa purchase price dahil mabilis masyado ang tread wear.
Kung malakas lakas sana engine ng L300 baka better sa iyo 195R14. Better stick with 185R14 na lang.
Thank you!
