Results 1 to 7 of 7
    Sep 2010
    Sirs,
    just wanna ask if there would be problem that might arise if i use 185/60 tires in front and 185/65 rear. By the way i'm using Rim 14. Some says, a problem may arise in the uneven wearing of tires, suspension, etc..Can i ask opinions from the masters/mechanic here?
    Thanks a lot!
    Feb 2009
    Quote Originally Posted by rocel View Post
    Sirs,
    Thanks a lot!
    there shouldn't be a problem unless you have anti lock brakes or awd drivetrain
    Sep 2010
    sir,thank you!can you please elaborate, i just don't have an idea of "anti lock brakes/awd drivetrain..thank you sir!
    Feb 2009
    with abs, all the speed sensors must have the same rotational speed or the same pulses from the wheel speed sensors except on turns for the abs to be able to activate should the wheels start to lock up. as with awd, you will have three differentials; front, center and rear. the center differential will always be compensating regardless you are traveling straight
    I am planning to replace tires for my pajero, currently using bridgestone dueler 31x10.50 R15. Any suggestions for a cost effective yet durable brand of tires.
    Quote Originally Posted by bombit4 View Post
    Try mo sir Savero.
    Sep 2010
    i see, that is only applicable to cars with sensors,am i right sir? since my car is toyota xl 94,would you think it will be safe mechanically wise havin that tire combination?thank you sir!
tire question
