Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jul 2012
    mga sir, is it ok to mix tire sizes? i currently have 185/55r15 installed, may nagbebenta sakin dalawang 195/55r15, balak ko sana bilhin. so ang maging setup ko is 2pcs 195/55r15 at the back and 2pcs 185/55/r15 front. is this ok? honda jazz po auto ko. panu po ba basahin ang mga tires size details? when i looked at the car may naka indicate na 185/55r15 82v. panu po ba babasahin ito? Thanks!
    Mar 2012
    Quote Originally Posted by nashimoto View Post
    185 - thread width / tire width
    55 - % of thread width as tire wall (height) 185x55 = 101.75
    r15 - wheel radius 15"
    82 - load index 475 kg
    v - max speed rating 240kph
    Car Bibles : The Wheel and Tyre Bible Page 1 of 4
    Mar 2012
    once ibang size ang kinabit na tires versus sa stock specs.. speedometer readings will not be accurate.
    185/55/R15 - Current rolling circumference 1762.81mm
    195/55/R15 - New rolling circumference 1795.98mm
    difference = 33.17 or 1.88%
    cruising speed of 60kph is actually 61.13 kph
    Car Bibles : The Wheel and Tyre Bible Page 4 of 4
    Minimal Lang naman yun difference
    Sent from my iPad using Tapatalk HD
    Mar 2012
    share ko lang experience ko dyan sa changing the tire size.. stock size 145/70/R13 on a 5.5" wide rims, palit ako ng 175/60/R13 on a 6" wide rims
    The result, sayad sa rear fenders pag 4 passengers sakay.. since yung stock specs ay hindi usle sa body nung car at yung new specs ay nakaapekto sa offset ng wheels. The solution suggested ng casa - return to original stock specs.
    My solution - since i like the wider tires, i installed lifters. sa pagpapalit ko pa lang ng tires tumaas na ng 3.5mm yung tire wall plus around 1 and a half inch na lifter.
    In your case, I dont think 5.5mm increase sa tire wall/height would be enough para sumayad yan sa fenders/body since you are maintaining the same rim width... minimal lang un eh
    Jun 2012
    Quote Originally Posted by stickers View Post
    possible din because of the width of the rims + wrong offset.
    Tama wrong offset, hinde na kasi katulad ng before na Basta mags Palit ok na...
    with regards to rolling circumference....is there a way to calibrate the speedometer kung sakaling baguhin yung tires from stock to a customized size?
    if yes, saan po ang shop? TY po Masters!
    Jul 2012
    thanks mga sir, clarify ko lang, does this mean mas malapad ang 195 vs 185? di po ba mas maganda kung malapad ang gulong kasi mas stable ang takbo ng auto? yung height, yan yung sukat from the rim to the thread? yung wheel radius yan po yung sukat ng rims? thanks!
    Mar 2012
    does this mean mas malapad ang 195 vs 185? - Yes
    di po ba mas maganda kung malapad ang gulong kasi mas stable ang takbo ng auto? - not necessarily
    yung height, yan yung sukat from the rim to the thread? -yes
    yung wheel radius yan po yung sukat ng rims? -yes
using diff sizes for tires
