Results 1 to 10 of 12
- Jul 2012
- 345
December 6th, 2012 11:01 AM #1mga sir, is it ok to mix tire sizes? i currently have 185/55r15 installed, may nagbebenta sakin dalawang 195/55r15, balak ko sana bilhin. so ang maging setup ko is 2pcs 195/55r15 at the back and 2pcs 185/55/r15 front. is this ok? honda jazz po auto ko. panu po ba basahin ang mga tires size details? when i looked at the car may naka indicate na 185/55r15 82v. panu po ba babasahin ito? Thanks!
December 6th, 2012 12:21 PM #2
185 - thread width / tire width
55 - % of thread width as tire wall (height) 185x55 = 101.75
r15 - wheel radius 15"
82 - load index 475 kg
v - max speed rating 240kph
Car Bibles : The Wheel and Tyre Bible Page 1 of 4
December 6th, 2012 12:32 PM #3
once ibang size ang kinabit na tires versus sa stock specs.. speedometer readings will not be accurate.
185/55/R15 - Current rolling circumference 1762.81mm
195/55/R15 - New rolling circumference 1795.98mm
difference = 33.17 or 1.88%
cruising speed of 60kph is actually 61.13 kph
Car Bibles : The Wheel and Tyre Bible Page 4 of 4
December 6th, 2012 12:47 PM #4
Minimal Lang naman yun difference
Sent from my iPad using Tapatalk HD
December 6th, 2012 01:00 PM #5
share ko lang experience ko dyan sa changing the tire size.. stock size 145/70/R13 on a 5.5" wide rims, palit ako ng 175/60/R13 on a 6" wide rims
The result, sayad sa rear fenders pag 4 passengers sakay.. since yung stock specs ay hindi usle sa body nung car at yung new specs ay nakaapekto sa offset ng wheels. The solution suggested ng casa - return to original stock specs.
My solution - since i like the wider tires, i installed lifters. sa pagpapalit ko pa lang ng tires tumaas na ng 3.5mm yung tire wall plus around 1 and a half inch na lifter.
In your case, I dont think 5.5mm increase sa tire wall/height would be enough para sumayad yan sa fenders/body since you are maintaining the same rim width... minimal lang un eh
December 6th, 2012 01:07 PM #6
December 6th, 2012 01:21 PM #7
Tama wrong offset, hinde na kasi katulad ng before na Basta mags Palit ok na...
December 6th, 2012 01:56 PM #8
with regards to rolling circumference....is there a way to calibrate the speedometer kung sakaling baguhin yung tires from stock to a customized size?
if yes, saan po ang shop? TY po Masters!
- Jul 2012
- 345
December 6th, 2012 03:27 PM #9
December 6th, 2012 03:35 PM #10
does this mean mas malapad ang 195 vs 185? - Yes
di po ba mas maganda kung malapad ang gulong kasi mas stable ang takbo ng auto? - not necessarily
yung height, yan yung sukat from the rim to the thread? -yes
yung wheel radius yan po yung sukat ng rims? -yes
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
