Originally Posted by
dr. d
but when did the problem arise? before the repair, or after? if after, it's likely something wrong was done... in-appropriate repair kit... wrong adjustment (yeah, the pushrod clearance; it's my favorite, because of previous experience.. it's also probably the easiest to remedy..). the hydrovac and the master cylinder actually are designed as a matching set. you can't mix and match them, because the pushrod clearance will change..
yes, as ln1 says, improper bleeding is also a suspect..
btw, how long have you had that car?
