Results 11 to 20 of 25
January 13th, 2008 10:02 AM #11
akin yun tok tok sound lumalabas lang after 30 minutes of continuous driving and nawawala kapag more than 60kph takbo ko. Ano kaya ito ?
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 13th, 2008 11:34 AM #12probably the cv joint.
kung malakas magbawas yung ps fluid you might have a leak sa ps rack mo.
January 13th, 2008 10:43 PM #13
thx sir speedyfix, pagawa ko sa inyo sabay ng change-oil tune-up ko na rin
January 13th, 2008 11:42 PM #14
eto po http://cruvensystem.com/
or sa RVC motor works sa felix ave..cainta near vista verde village or sta.lucia grandmall
sa RVC di sya basta basta magpapalit papakita nya muna sayo yung mga dapat palitan
January 13th, 2008 11:50 PM #15
nyay, i also have the same problem. recently (2wks ago)nagpagawa ako kay zee sa aurora. halos lahat either palit or repair(inject) na. i didnt question nor doubt mga pinapa gawa sa akin. go ahead lang ako sa lahat.
now just this week habang pa atras ako then turn the steering wheel to the left. while turning... may tok tok sound sa front right wheel. ano kaya ito?
another problem... i lost the receipt already. pano na kaya?
January 14th, 2008 11:58 PM #16
same sound ba from your problem 2 weeks ago?
medyo similarr nangyari sa akin before. turns out nag-loose lang yung mud guard (probably not the right name) sa loob ng wheel well and tumatama sa wheels ko when I turn. akala ko that time CV joint na problem ko, almost the same kasi yung sound.
- Nov 2003
- 3,848
- Jan 2008
- 42
January 20th, 2008 11:43 PM #18
chief i also have the same problem, lumalagotok pag lumiliko at minsan kahit di lumiliko at uneven yung road kumakatok, at yung greese niya kumakalat punit yung boots
pwede ba lagyan lang uli ng greese at palit boots as a remedy or talagang palit na buong CV?
how much yung CV?Last edited by zach09; January 20th, 2008 at 11:45 PM. Reason: need additional questions
- Apr 2007
- 42
January 26th, 2008 07:33 PM #19thans po sa mga nagreply...
i already have the cv joints and engine supports changed, inayos rin tie rod kasi medyo maluwag.nawala nga mga lagutok, kaya lang hindi na pantay gulong saka may kabig papuntang kanan. sabi po ng suking mekaniko ko kaya daw hindi pantay gulong at may kabig kasi may sinikipan daw siya sa tie rod. in short it needs wheel alignment and camber alignment if necessary.
so dinala ko sa servitek for wheel alignment and sabi nila hindi raw pwede i-align kasi kailangan daw palitan/fix ang mga ito:
1. (2) tie rod end...may kalog daw
2. (4) bushing (suspension) - big and small
3. (2) transmission axle
4. (2) shock mounting yata ito (hindi ko maintindihan sulat e)
ano po ba signs or pakiramdam na my problema yang mga parts na iyan?
parang duda kasi ako kasi wala naman ako nararamdaman na kakaibang tunog sa pangilalim ng oto. isa pa bigat sa bulsa, halos 12k po estimate damage including wheel alignment. plus 900 camber alignment both sides.
tulong naman po.
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
