Results 21 to 25 of 25
January 27th, 2008 03:20 AM #21
Maybe its true. Kapag sira ang tie rod they cannot get it done the right way to align your car properly dahil doon ang setting ng toe. Maybe your mechanic adjusted your tie rod w/o inspecting on it. At yong mga bushing kapag pudpod na kailangan papalitan mo narin dahil puro alog na yan. Transmission axle????? eeeeemmmh I dont know about this, never heard a tranny axle before, strike that one. Remember when change, change it in pair.
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 27th, 2008 09:41 AM #22normally they will not align the car kung meron kahit konting sira sa suspension.
April 30th, 2008 01:20 PM #23
good day po mga guru's
question kolang po...regarding sa tok na tunog, nakaka experience din ako nito..
pero weird siya, pang tuwing may ulan tsaka tumutunog...
i just recently replace (2) ball joints, (2) tie rod, (2) front shocks and spring, (2) rubber boots (2) brake pads and (2) mounting but pag may konting lubak or paangat yung daan, pag nadaan ko, yung front right side ay may tok, isang beses lang..then pag mabilis takbo ko then pag preno ko may tok ulit sa front right side..
hinde kona pinalitan yung (2) rack end kasi 2006 ko pinapalit sa Toyota mismo..
ano kaya mga possible na problema?
i did try to TS myself and i found out that yung (1 out of 2) rubber bushing sa right side ng rock and pinion ay medyo maluwag...pinahigpit ko pero ganun padin..
ano kaya problema nun...
Any help would be greatly appreciated..
Corolla AE92 ride ko pala...
- Jan 2008
- 42
May 4th, 2008 01:05 PM #24Im back again mga chief , and this time totok sound parin but thats when i start running 1st gear and 2nd gear at nararamdaman talaga siya when i step on the clutch. but when i the car runs more than 30 40 kmh nawawala na siya and di siya tumutunod pag lumiliko pag straight lang pag dahan dahan ang takbo saka siya nag totok tok ang sound. need help on this tnx
- Jul 2003
- 573
May 4th, 2008 01:55 PM #25mahirap talaga maghanap ng tok tok sound problems sa sasakyan. dami puedeng panggalingan niyan. ang first step is to inspect every nuts and bolts
related to the suspension, front and rear. Make sure all bolts are properly tightened. Camber/Caster adjustments bolts are tight. Stabilizer bar bushings are not worn out. Stabilizer links have no side/end play. Inspect shock mounting for cracks. Look for signs of uneccesary parts or linkage movement. This is for the trained and experienced eye to detect. DIY maybe difficult unless you have a good mechanical aptitude.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
