Results 1 to 8 of 8
    May 2010
    Mga sirs baka po meron sa inyo me alam ng sagot. kasi ung ride ko pag nakahinto at pinihit ko sa kaliwa me na tunog na malakas na TOK! pero pag umaandar kahit sobrang bagal wala ung tunog. ung tunog lumalabas lang pag kinabig ko ng kunting kunti lang and me parang me humihinto ng unti sa pagkabig ko ng kaliwa. pero sa kabign g kanan wala naman ung sounds. Please advise naman po ng experts.
    94 LS Pick up po pala ride ko.
    CV joint yan bro....
    May 2010
    Sir magkanu kaya damage ng CV joint? need na ba ipagawa agad agad to? mejo tight budget ako for the month
    Jul 2003
    pa check mo muna steering rack ends at suspension bushings.
    May 2010
    napacheck ko na po, sabi ng mechanic samen center post daw po. everytime na kumakabig ako pa kaliwa e parang lumalagutok ung connection ng steering sa center post at need daw palitan na ung buong center post? tama kaya siya?
    ang problema ko ngayon e kaka camber allign ko lang pag pinaayos ko ba ung center post ko mawawala sa allign ung pick up ko? and also makatarungan ba ung singil saken na 3k for replacement and labor?
    Quote Originally Posted by Vhincent View Post
    tama lang yung damage, imho...
    Feb 2009
    center post? is that a jeep mb ( modified haltenberger type)? as far as i can recall, your isuzu pee cup has parallelogram type steering and do not have a "center post" . have your idler arm checked for possible banging against the frame when the steering is in full turn left
    Jan 2012
    kung tuloy tuloy yan pag liko like tik tik tik tik- CV JOINT ito, but kung isang Tok lang maaring sa Shock mounts or sa ball joint
TOK! sound when steering to left only
