Results 1 to 8 of 8
- May 2010
- 25
August 16th, 2012 04:41 AM #1Mga sirs baka po meron sa inyo me alam ng sagot. kasi ung ride ko pag nakahinto at pinihit ko sa kaliwa me na tunog na malakas na TOK! pero pag umaandar kahit sobrang bagal wala ung tunog. ung tunog lumalabas lang pag kinabig ko ng kunting kunti lang and me parang me humihinto ng unti sa pagkabig ko ng kaliwa. pero sa kabign g kanan wala naman ung sounds. Please advise naman po ng experts.
94 LS Pick up po pala ride ko.
- May 2010
- 25
August 17th, 2012 03:40 AM #3Sir magkanu kaya damage ng CV joint? need na ba ipagawa agad agad to? mejo tight budget ako for the month
- Jul 2003
- 573
- May 2010
- 25
August 20th, 2012 06:33 PM #5napacheck ko na po, sabi ng mechanic samen center post daw po. everytime na kumakabig ako pa kaliwa e parang lumalagutok ung connection ng steering sa center post at need daw palitan na ung buong center post? tama kaya siya?
ang problema ko ngayon e kaka camber allign ko lang pag pinaayos ko ba ung center post ko mawawala sa allign ung pick up ko? and also makatarungan ba ung singil saken na 3k for replacement and labor?
October 20th, 2012 03:38 PM #7
center post? is that a jeep mb ( modified haltenberger type)? as far as i can recall, your isuzu pee cup has parallelogram type steering and do not have a "center post" . have your idler arm checked for possible banging against the frame when the steering is in full turn leftLast edited by jick.cejoco; October 20th, 2012 at 03:49 PM.
- Jan 2012
- 12
October 21st, 2012 11:25 AM #8kung tuloy tuloy yan pag liko like tik tik tik tik- CV JOINT ito, but kung isang Tok lang maaring sa Shock mounts or sa ball joint
high idle RPM at engine start
