Results 1 to 7 of 7
June 8th, 2008 04:27 PM #1
Guys, if your ride is lower in front and your ride is rwd. do you lose some tractions on your rear wheels?
June 10th, 2008 08:31 AM #4
Disclaimer: This is a guess...
If the suspension loads the rear wheels just fine even with a lower front end, there shouldn't be a problem. Traction is, among other things, a function of weight over the driven axle and wheels. I'm not sure how exactly, but there may be a way of setting up the suspension to optimize traction even with a lowered front ride height.
Like I said, this is a guess...correct me if I'm wrong.
June 10th, 2008 09:24 AM #5
This is just my observation. It shouldn't lose any traction at the rear tires unless of course your front end has so much weight, maybe due to a heavier engine, that it tilts to the front. If that happens, then the car would be incredibly hard to steer.
Take this for example:
Although that car is designed for the drag strip, the front end is lower than the back end yet the chassis lay-out is still level despite the obviously heavier engine upfront.
June 10th, 2008 03:58 PM #6
It all depends on the rear geometry. How much squat it allows, how well it can keep the wheels on the ground... hard enough to push wheels into ground but soft enough to stop wheel hop or axle hop... etcetera.
In really slippery conditions, the static weight balance will matter more, but on regular roads, the suspension tuning plays a bigger part.
June 10th, 2008 08:19 PM #7
that makes sense. thanks a lot guys.
+rep added to all. except sir niky. cannot give more points yet.Last edited by rion; June 10th, 2008 at 08:25 PM.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
