Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
    Mar 2004
    #21
    Depende yun kung gaano kabigat na lead kailangan para mabalance yung tires. It could have gone the other way. Puno't dulo e ma balance yung rim para di mag wiggle at high speeds.
    Jun 2005
    #22
    Quote Originally Posted by stradakid View Post
    If you're tires are not lahat the same age, yung mas bago sa harap. Mas mabilis ma wear sa harap lalo pa pag car.
    Agree. Agree.
    Aug 2005
    #23
    Nung nagpalit ako ng tires nag pa align ako sa Goodyear Servitek, imbes na walang kiling e nagkaroon at malakas talaga. Binalik ko, nawala yung kiling sa kanan, sa kaliwa naman pumunta. Bahagya lang naman. Tinamad na akong magpunta uli para ipa back job. Masama noon e nagbayad pa ako sa alignment.Magaling pa yata sa Blumentritt.
    sir got same problem dati.. my lesson is di talaga tamang eh align sya if okey pa ang alignment.. dapat lng palit tires at salpak lang. so sensitive ang aligment pag nasira na mahirap eh balik sa dati .
    posted by stradakid:
    ganun yung sa auto ko. yung dalawang bago (sabay nabili) sa harap tapos sa likod yung luma. so kung ganito ang sitwasyon, di na applicable ang tire rotation?ganun nga ba?
    Jan 2004
    #25
    Quote Originally Posted by j_avonni View Post
    Nice tips, driven. I'm on my 28,000 kms. After I rotate my tires at 30,000 kms, I'd do the rotation every 5,000 kms. Thanks.
    anytime dude
    Jan 2004
    #26
    madugo yan kung AWD
    #27
    Quote Originally Posted by asterix View Post
    when my tires were rotated, I noticed that my rims have different sizes of lead weights. The front tires have smaller lead weights than the rear tires. Would this affect my wheel balance? What will be the expected effect?
    Wheels are balanced while they are not installed on the vehicle.
    They couldn't care less what position they get put back in unless you are using directional wheels/tires or tires of different sizes.
    Mar 2004
    #28
    Quote Originally Posted by driven View Post
    madugo yan kung AWD
    Im driving a 4x4. Mas madali talaga mapudpud ang harap, bukod sa mabigat ang front dahil sa engine e that's where you steer.
    Jul 2006
    #29
    How do you incorporate the spare in tire rotation?
    Apr 2005
    #30
    it might be in your manual.
    Feb 2006
    #31
    i do the rotation myself every 10k, i'm planning to make it every 5k (kung sipagin). ganda kasi ng result when you rotate, i always end up buying 1 set of tires in a span of 4-5 yrs. ang sarap pa magpa-align pag 4 new tires, alang kabig talaga
    Aug 2003
    #32
    better if you can include the spare tire in the rotation. If not, then rotate the 4 tires. But when you replace the worn out tires, you must use the spare tire among the 4 because the rubber in the tire only has a recommended life span of 5 years. Beyond that, tires, especially the sidewall, has tendency to become brittle or less flexible.
    Aug 2006
    #33
    to those without manuals, here is the schematic diagram i copied from a chevy colorado manual:
    tire rotation without using spare
    Front
    O O
    1 2
    O O
    3 4
    1 goes to 4 , 4 to 2, 2 to 3, 3 to 1
    tire rotation including spare tire
    Front
    O O
    1 2
    O O
    3 4
    O
    Spare
    this is a little bit complicated...
    Spare to 4, 4 to 2, 2 to 3, 3 to 1, 1 becomes the spare
    HTH
Tire Rotation
