mga sir ok lang ba na stock ko lang sa bahay yung
mga tires ko? let say for 1 yr...hindi ba masisira?
I say atleast have them rolled every 3 months to get the rubber expanding a bit.
magiging brittle overtime kung hindi mo pagugulungin some time.
almost one year na yung stock wheel n tire ng wrx ko na nakastock lang sa garahe, havent rolled it yet. Maybe it wont be rolled until who knows when...hahaha.
agree. rubber becomes brittle when left dormant.
try to put them on once in a while para naman magamit din sila. kahit 1 or 2 days lang then tangalin mo nalang ulit!![]()
Originally posted by pajerokid
Kung 1 year mo i-stock there's a chance na ma-deform ng kauntishet, maibalik nga muna this weekend nyhahahahaha. Nagamit ko lang sila for a month, sayang nga naman.
naku kasi iniwan ko lang sa bahay yung 1 set ko hindi
nakalagay sa kotse ito..
walang mag aasikaso nun fo4 a year...sana naman
pag balik ko ok pa...
benta ko na lang..hehheee falken ziex 205/45/16
bilhin nyo na..masisira lang pala sa bahay ito
95% thread pa..heheheh
eto pic..www.pbase.com/ozcity18
load? as in air? may 32psi each tire and naka lapag ng sideways, away from sun, weather, etc., kse nasa loob ng garage. ilalagay ko na din, para sigurado.Originally posted by pajerokid
Karding, kung wala naman load pare oks lang siguro.
nope, load as in car. If its stored sideways and properly inflated youre okay. Yung tire deformation that i mentioned is due to the weight of the car pressing down on the tires. diba the part of the tire in contact with the ground looks flabby compared to the upper part? That deformation could imprint itself to the tire if left in the same position too long. :D
kung ganun, how does tire manufacturers store their tires?
Signature
Dapat you lay them on their side and stack them on top of one another with a piece of cardboard in between. Keep away from direct sunlight, extremes of temperature, and ozone generators (mostly electric motors?). Much better din if the rims are separated from the tires.
Curious lang ako, di ba pag nagpalit tayo ng gulong ng oto from let's say stock na 14" to 16"-paano nga pala yung spare tire? OK lang ba na yung stock spare tire kabit mo up to the vulcanizing shop?
Yup, pwede pong gamitin pansamantala. Pero may mga spare tire na ubod ng nipis ng goma na may speed limit at hangganan ng gamit. I think it's good for 500kms or less.
Ok lang yun basta halos pareho ang overall diameter.
Sa U.S. halos lahat ng sasakyan, temporary spare lang ang gamit. Yung sobrang kitid na gulong on a steel rim. Good for 90kms up to 90 kph. Basta same as stock ang outer diameter.
