Results 1 to 5 of 5
November 7th, 2008 06:35 PM #1
Greetings Tsikoteers,
ask ko lang if there is a website or thread here in the forum that can accurately provide me information on the recommended tire pressure settings (front & rear) for particular tire series. For example, ang gamit ko ngayon is 205/55/ R15 na gulong para sa corolla '89 small body type. Currently, nasa 32psi ung hangin sa lahat ng gulong ko. I'm not sure din kung un ang isang cause kasi kung bakit mejo matagtag ung takbo ng auto. Would appreciate the advice.
Thanks in advance.
November 7th, 2008 06:42 PM #2
Possibly. What's the recommended pressures on your door jamb (the part of the car body covered by the driver's door)?
For older and lighter cars, you don't really need very high pressures. 29-30 will do.
November 7th, 2008 07:20 PM #3
many thanks for the reply.
i read about that on one internet site earlier, try ko silipin sa auto ko mamaya kung meron nun sa may door side.
November 7th, 2008 09:05 PM #4
like niky said, you can see the recommended tire pressure sa driver side door. kaya lang it is for the stock/recommended tire size.
hindi ata 205/55/ R15 ang stock tires ng corolla 89.
November 8th, 2008 10:30 PM #5
nga pala good point there, hindi nga stock ung gulong ko so malamang N/A na ung information sa driver door ko.
high idle RPM at engine start
