Results 1 to 6 of 6
- Jul 2007
- 19
August 10th, 2007 07:28 PM #1my tires have uneven worn-outs especially on the sides of it.i think it is under inflated. just want to ask what is the proper tire pressure of this tire size (31 X10.5 X r15LT).
thanks in advance.
August 10th, 2007 08:50 PM #2
What vehicle? And is that the original tire size for that vehicle?
The door jamb on my old Pajero said TP should be 50psi. I think it was just a joke. I used around 32 psi all around.
Check your alignment.
- Jul 2007
- 19
August 15th, 2007 02:57 PM #4
Hi kross
I have a 98 4x4 HiLux and am running that tire size now.
I noticed that 29-30 psi is good. I use 30.
Ride is better and tire wear is even.
If wear is only at the front, check your underchasis parts alignment to see if everything is up to spec.
Any discrepancies, no matter how small, can result in uneven wear and other problems.
If wear is on all four tires and only on the outer edges (left and right) of the tire then, yes, it is under inflated.
Hope this helps
:regards:
- Jul 2007
- 19
Not sure if functional nga ba pero yung ibang turbo daw water-cooled na versus oil-cooled. Kaya...
0dometer problem
