tanong lang.
san nakakabili ng stabilizer bar (fronts) for Lancer Pizza? kailangan ko atang lagyan yung oto ko.
OEMs not necessary. kung may surplus, ubra din.
tanong lang.
sir mukang malupit kayo sa turning ha? hehehe
anyway, sa banawe po madami sway bars... performace shops like kai racing have them. hindi naman hard to find for the pizza. kung used naman, most japan surplus shops have them.
sa south naman, kay hongly meron yan.
hth![]()
strut bar ba sinasabi mo? marami sa car accessories shop yan, less than 2k siguro ngayon yun mga Taiwan generic...
hindi ko na sure kung kano na ngayon sway bars... yung alala ko sa EG dati, less than 5k... forgot the brand though.
hongly, lapit sa SM sucat... usually may nakapark dun evo 8 and evo 9.. kahelera ng SM sucat.
edit: get the ralliart sway bars na...
umm.. hindi po sturt bar. pang suspension po yung stabilizer bar, for better handling. yung strut bar para sa engine.
are you refering to the round material that connects the fr lower arms of lancer pizza? its a stock suspension component for lancer pizza. it should be installed from the factory. mine has one.
Are the generic or cheaper versions of this perform just as well as the branded ones?
^^ if you just use it as a daily driven... it perfectly fine to use cheaper one's pero if you do circuits then ull need the branded sway bars for maximum use of the upgrade.
AFAIK, mas mabigat yung mga cheaper and easier to brake if used roughly.
ang panget lang sa sway bars is kung unlevel surface drive dadaanan mo then parang seesaw effect magyayari sayo. hehehe
edit: it takes some getting used too![]()
no, its not the axle im talking about. can you post a pic of what you are referring to.
as i have stated above, it connects the lower arms. the axles connect the knuckle hub to the transmissin differential.
afaik, walang sway bar ang pizza sa stock... differential arm lang ata yung sinasabi mo...
anyway, i'll look lang at those generic stuff muna...
see the screenshots i made for the parts list database of a ck2 body as well as the service manual of a ck2. - lancer pizza
mine came with one installed. it's the rear sway bar which is not stock.
ayun. rear... rear talaga is stock/oem ng lancers.
ang hinahanap ko is front....
ive consulted with my friend that has the evo 8.
tama, the front sway bars are stock sa lancer as well as other sedans... the problem with those is hindi maganda yung handling niya on cornering. notice the vertical bolt and different curves for the upgraded and the horizontal for the stock.
yung pagkaexplain niya sakin is yung stock has too much “play” daw and does not do the job on cornering. the side rolls cannot be prevented by the stock ones. sa upgraded yung nagbibigay ng more accurate “play”. im really sure how much or less play that the upgraded ones do offer pero i just took his word for it kasi siya yung may lancer.
also the upgraded is wider than stock sway bars.
i think we are in a bit of confusion here...
the screen caps which i made are the front of lancer pizza. stabilizer bar IS STOCK for lancer pizza.
the rear suspensions of pizza's DO NOT have stock stabilizer bars.
If you want sharper steering, front sway bars will help, but if you want sharper handling, focus on upgrading the rear sway bar first, to lessen understeer.
