tanong lang.
san nakakabili ng stabilizer bar (fronts) for Lancer Pizza? kailangan ko atang lagyan yung oto ko.
OEMs not necessary. kung may surplus, ubra din.
tanong lang.
sir mukang malupit kayo sa turning ha? hehehe
anyway, sa banawe po madami sway bars... performace shops like kai racing have them. hindi naman hard to find for the pizza. kung used naman, most japan surplus shops have them.
sa south naman, kay hongly meron yan.
hth![]()
strut bar ba sinasabi mo? marami sa car accessories shop yan, less than 2k siguro ngayon yun mga Taiwan generic...
hindi ko na sure kung kano na ngayon sway bars... yung alala ko sa EG dati, less than 5k... forgot the brand though.
hongly, lapit sa SM sucat... usually may nakapark dun evo 8 and evo 9.. kahelera ng SM sucat.
edit: get the ralliart sway bars na...
umm.. hindi po sturt bar. pang suspension po yung stabilizer bar, for better handling. yung strut bar para sa engine.
are you refering to the round material that connects the fr lower arms of lancer pizza? its a stock suspension component for lancer pizza. it should be installed from the factory. mine has one.
Are the generic or cheaper versions of this perform just as well as the branded ones?
^^ if you just use it as a daily driven... it perfectly fine to use cheaper one's pero if you do circuits then ull need the branded sway bars for maximum use of the upgrade.
AFAIK, mas mabigat yung mga cheaper and easier to brake if used roughly.
ang panget lang sa sway bars is kung unlevel surface drive dadaanan mo then parang seesaw effect magyayari sayo. hehehe
edit: it takes some getting used too![]()
no, its not the axle im talking about. can you post a pic of what you are referring to.
as i have stated above, it connects the lower arms. the axles connect the knuckle hub to the transmissin differential.
afaik, walang sway bar ang pizza sa stock... differential arm lang ata yung sinasabi mo...
anyway, i'll look lang at those generic stuff muna...
If you want sharper steering, front sway bars will help, but if you want sharper handling, focus on upgrading the rear sway bar first, to lessen understeer.
Try the rear muna... get a front strut bar muna to tighten it up a bit and a rear stabilizer. See how it runs then decide if you still want the front stabilizer. ;)
hmmm... tama si sir niky... since there is a sway bar stock sa lancer, even if the front stabilizer bar does not preform as well as the aftermarket, the rear would be the logical choice. then kung hindi pa satisfied sa handling... go for the front na rin![]()
correct me if i am wrong, but the rear sway bar of pizza would require a new set of lower arm right? i am not sure i might have interchanged itlog config from pizza
