Results 1 to 9 of 9
- May 2011
- 4
May 14th, 2011 07:44 PM #1help nmn po.. wat probably ung problem nung front disc break ng auto ko.. nissan ex saloon 1999..nakadikit kc ung disc break.. nagiinit ung disc break..thank you
May 14th, 2011 08:00 PM #2
if your pads are so worn out and your caliper pistons stuck out beyond designed limits because of too thin brake rotors and too thin brake pads, they might not retract from caliper seal memory retention. the pistons too, if they are rusted because of torn dust boots will seize and not retract. remember, there is no return springs for the caliper pistons. the other possibility is that the brake hoses might have restriction. it might have residual pressure because of this constriction in the hose and it tends to build up heat and pressure thereby self applying the front brakes when you don't need it to.
May 14th, 2011 08:23 PM #3
hehehehehehe. just re-reading, stuck up or stuck? i kinda noticed this "stuck up" phrase
May 14th, 2011 08:53 PM #4
- May 2011
- 4
May 14th, 2011 09:49 PM #5thank you po sa advice..bgong palit po ung break pads nung disc break..d nga po nmin mfugure out kung ano ang problma.. nilinis n dn nmin ung piston nya..ung hose n lng po check nmin.. thnk you po ulit
- May 2011
- 4
- Sep 2008
- 630
- May 2011
- 4
- May 2011
- 12
May 17th, 2011 01:22 PM #9Check Auto Doctor , they specialized in Underchassis and Aircon
http://www.sulit.com.ph/index.php/vi...+SPECIALIST%29
